February 10, 2026, 04:15:18 AM *
Author Topic: shifter seal  (Read 1182 times)
N0tac0p
« on: April 03, 2015, 12:30:33 PM »
finally leaking.  I thought I saw somewhere trick in replacing....also wondering how much if any oil I may lose..
any help greatly appreciated
« Reply #1 on: April 03, 2015, 12:35:23 PM »
Remove shift leer. Remove old seal with a small sheet metal screw. Clean up the seal area. Put a little grease on the inside of the seal to hold that spring in. DO NOT ASK. Install new seal. Install shift lever. Go fer a ride.  cooldude Easy peasy!  2funny RIDE SAF.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: April 03, 2015, 01:03:35 PM »
http://lifeisaroad.com/valkshiftseal.html
« Reply #3 on: April 03, 2015, 05:12:59 PM »
Inspect alignment mark on shifter and rod before removal. Mark if necessary.
RonW
Newport Beach
« Reply #4 on: April 04, 2015, 02:43:53 AM »
I had all the tools out, but than decided to press the old shifter seal fully back into its recess. It was sticking out about an ⅛ of an inch all around. Seemed to have stopped the leak. It's been just a few days. I cleaned the immediate area nice and shinny with brake cleaner, so far there isn't any detectable leaks on the aluminum nor drips on the card board. Btw, that little rubber donut cost me $10 postage.
« Last Edit: April 04, 2015, 02:47:45 AM by RONW » Logged
2000 Valkyrie Tourer
Tfrank59
'98 Tourer
Western Washington
« Reply #5 on: April 04, 2015, 09:08:38 AM »
Last summer my shifter seal started leaking a little bit (only talking a few drops), so I bought the seal and changed it out.  What I noticed though was it was very difficult to press the new seal all the way back into the counterbore, even though I watched the video and did it just like that (my new seal is basically flush with the case – not sticking out at all).  So far I don't have any leaks and it's been about 6000 miles.  But what I did is  bought another seal – only like four bucks apiece -- and made a special aluminum install bushing, so that next time I have to change it out I'll be able to press the new seal in all the way, which is of course required to fully contain oil in the gear box. cooldude
-Tom
« Reply #6 on: April 04, 2015, 09:12:22 AM »
I did this exact same thing.  It did work, for about a year then when it started leaking again, I replaced it.  Been a number of years now with no leaks
