February 10, 2026, 04:16:17 AM *
Author Topic: O rings in rear Diff.  (Read 812 times)
Jruby38
Oxford Mass.
« on: April 05, 2015, 06:01:36 AM »
I am doing rear tire and maint. I can only find two on the O rings, Is there a pic of the locations? The splines and hub are mint with my homemade lub of waterproof green grease and Lyman bullet molycoat powder mixed.
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #1 on: April 05, 2015, 06:08:44 AM »
Click on the shop talk page at top and under tech tips on the left column down click on Rear end service by chrisj. You'll find everything you need there including pics  cooldude
F6BANGER
Albuquerque NM
« Reply #2 on: April 05, 2015, 06:12:24 AM »
bassman
« Reply #3 on: April 05, 2015, 06:28:42 AM »
http://www.valkyrieriders.com/shoptalk/Elusive%203rd%20O-Ring.htm
Jruby38
Oxford Mass.
« Reply #4 on: April 05, 2015, 02:10:45 PM »
Thanks. The one I cant find is because its on the wheel out for mounting.  I even bitched up the dust seal looking there.  have to buy a new one.  I should have asked or looked better first.
« Reply #5 on: April 05, 2015, 08:16:24 PM »
I am doing rear tire and maint. I can only find two on the O rings, Is there a pic of the locations? The splines and hub are mint with my homemade lube of waterproof green grease and Lyman bullet molycoat powder mixed.
Member Ratdog use to make a schmooie of Bel Ray waterproof grease and Hondas moly paste. I wouldn't use a moly powder in a grease. Personally I use Bel Ray alone and still have no wear at 148K.
