February 10, 2026, 04:15:13 AM *
Author Topic: Harbor Freight tire changer, motorcycle attachment is now available and on sale  (Read 2101 times)
Brian
Monroe, NC
« on: April 06, 2015, 03:38:39 PM »
Okay gang, I am going to gear up to start changing my own tires. HF now has both items on sale. Recommendations needed on the best tools to prevent damage to the rims.
Thank you.
wingrider02
Maple Lake, MN
« Reply #1 on: April 06, 2015, 03:55:16 PM »
Mojo blocks are almost a must with HF tire changer.  A Mojo lever, No mar, or comprable tire changing lever is also recommended.   Some large tire irons or spoons to get the stiff sidewall moved around.  Get some tire lube as well.
I highly recommend watching the video's on how to change tires on the NoMar site, as well as you tube to figure out your technique.
Brian
Monroe, NC
« Reply #2 on: April 07, 2015, 02:31:35 AM »
I went on the mojo site after posting this question. There are 3 different types of blocks so I suppose I need to see what style is required after I get the HF set-up. I can't believe their lever is $100 bucks but probably worth it to not damage an expensive rim. Thanks for the info and suggestions.
wingrider02
Maple Lake, MN
« Reply #3 on: April 07, 2015, 07:37:40 AM »
Yep, three different style blocks, and you don't know what you need till your HF part gets here.
Yea, the lever is a little spendy...another fella I know got the Nomar one instead, said he liked it better, so do your homework before you run out and buy stuff!  Smiley
I ended up bending the bolt on the Mojo, but it was most likely due to inexperience, and bad technique.
Tip for you, be sure the tire you are taking off, or putting on is warm, like sit in the sunshine warm.  A cold tire is a lot tougher to fight off and on than a warm one.
quexpress
Montreal, Québec, Canada
« Reply #4 on: April 07, 2015, 12:27:18 PM »
It's worth every penny paid for it!  cooldude
I have the Mojo Lever and also the No-Scuff tire tool. You can't lose with either one of these.
Link to the No-Scuff tire tool. There's lots of good info.  Smiley
http://www.no-scufftiretool.com/
I still have a full deck.
I just shuffle slower ...
Brian
Monroe, NC
« Reply #5 on: April 07, 2015, 04:58:07 PM »
Thanks for the great advice wingrider.
Brian
Monroe, NC
« Reply #6 on: April 07, 2015, 05:02:01 PM »
Thanks. I will probably try the mojo ordering it with the blocks.
