trouthunterjohn
« on: April 07, 2015, 12:20:56 PM » |
I am upgrading my turn signals to led and also plan to replace my relay with an led compliant unit.
Where is the relay located on my 98 valk std? I tried a few searches here and on Google with no luck.
Thanks.
« Reply #1 on: April 07, 2015, 12:25:46 PM » |
trout dude
« Reply #2 on: April 07, 2015, 12:26:13 PM » |
It is in front the battery box Hope this helps
« Reply #3 on: April 07, 2015, 12:26:49 PM » |
I believe you can access it from the left side cover.
BobB
« Reply #4 on: April 07, 2015, 12:46:31 PM » |
It is centrally located in front of the battery box. The easiest access is from the left side, removing both the cover and the coolant overflow reservoir.
« Reply #5 on: April 07, 2015, 01:21:23 PM » |
I discovered that even with a new flasher you may also need a diode setup or the LED blinkers will be out of whack. At least that's the case with my white/amber switchback LED 1157 bulbs. I'm waiting on the diode kit to arrive, ordered the Kuryakyn one. http://www.valkyrieforum.com/bbs/index.php/topic,69876.0.html
« Last Edit: April 07, 2015, 03:45:51 PM by Valkorado »
BobB
« Reply #6 on: April 07, 2015, 06:52:15 PM » |
I discovered that even with a new flasher you may also need a diode setup or the LED blinkers will be out of whack. At least that's the case with my white/amber switchback LED 1157 bulbs. I'm waiting on the diode kit to arrive, ordered the Kuryakyn one. http://www.valkyrieforum.com/bbs/index.php/topic,69876.0.htmlEven with a proper flasher, you will get left/right cross flashing due to the reduced resistance of the LED bulbs. The diode Y's, if installed correctly, can resolve it. But I found that leaving the standard 1156 bulbs in the rear turn signals also resolves the issue.
trouthunterjohn
« Reply #7 on: April 07, 2015, 09:24:36 PM » |
Thanks guys. Looking forward adding led bulbs and new flasher. Hopefully a simple upgrade.
« Reply #8 on: April 08, 2015, 05:19:59 PM » |
FYI I replaced my flasher with a Kisan one 15 years ago and it has handled every turn signal mod I've thrown at it. There have been quite a few - LEd's, Highlighter wired for run brake & turn, rear signal changed to 1157's then 1157 LED arrays, wired with run brake & turn, front signals tungsten then LED. The Kisan unit is spendy however it supports a lot of options. Mine is an older one with fewer options. Don't need them, I've added the same options plus more with my own circuits.
nogrey
Nampa, Idaho
« Reply #9 on: February 21, 2017, 09:04:01 PM » |
Hey Mark: 2 Questions: 1) Where does one acquire the correct kisan flasher unit and 2) (gulp) Can I afford a set of those turned down pipes like you show on the red bike in your photos? I LOVE them! But, like some of the supermodels that I admire, I may have to admire them from a distance!
« Reply #10 on: February 21, 2017, 09:39:06 PM » |
Hey Mark: 2 Questions: 1) Where does one acquire the correct kisan flasher unit and 2) (gulp) Can I afford a set of those turned down pipes like you show on the red bike in your photos? I LOVE them! But, like some of the supermodels that I admire, I may have to admire them from a distance!  https://kisantech.com/mag/signalminder.htmlThe pipes depend on things like, do you have cores you want them built from, or cores from me; and other options like 5 or 4 inch (mine are 5), Crossover or not (mine has that). With those answers I can quote. Best to do that offline. email is valkstuff@horseapple.com
