January 29, 2026, 01:58:12 PM *
Author Topic: sudden rear tire leak  (Read 1849 times)
KCvalk
Alexandria VA
« on: August 26, 2009, 09:17:38 AM »
41lbs of pressure worked fine then all of a sudden it down to 22lbs  3x's  with no sign of tread puncture
(used water and dishwasher soap to look for bubbles nothing on tread or sidewall) inspected the entire tire?
it has the rubber stems and i am wondering if something has worked loose with them?
any ideas?
the armor of the Valkyries "sheds a strange flickering light, which flashes up over the northern skies" making the aurora.
« Reply #1 on: August 26, 2009, 09:25:57 AM »
any ideas?
Use the soapy solution to check also around the bead and at the valve, most especially at the valve.
Daniel Meyer
The State of confusion.
« Reply #2 on: August 26, 2009, 09:26:09 AM »
any ideas?
Yeah, soap up the stem and then bend it over with your fingers. Chances are it leaks then.
CUAgain,
Daniel Meyer
Jay
« Reply #3 on: August 26, 2009, 09:29:56 AM »
Check the schrader valve as well as the stem.
9Ball
« Reply #4 on: August 26, 2009, 09:44:45 AM »
is the black plastic support still there? or broken?  That would allow the valve stem to flex and leak.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Spirited-6
Nicholasville, Ky.
« Reply #5 on: August 26, 2009, 10:50:22 AM »
any ideas?
Air up to 50# and check again. reduce to normal and watch.  Smiley
Spirited-6
Thunderbolt
Worthington Springs FL.
« Reply #6 on: August 26, 2009, 05:27:22 PM »
if you have rubber OEM stems.  I had one leak down around the stem.  I put the metal 90 degree stems in from Patchboy.
Big Rig
Woolwich NJ
« Reply #7 on: August 26, 2009, 06:34:00 PM »
What type of tire?? on my last set of OEM's I had the same thing...tried every trick I could think of, even pulled the rear and submersed it in a tub of water...nodda, was going to take the tire to change it out and running my hand over the rubber while wheeling it into the garage, I felt it...one one the wire bundles broke and worked it was thru the tire...must have hot something harder than I thought...anyway, took needle nose pliers and pulled out a wire strand about an inch long....checked the tire off the rim and about 50 of them were sticking out like a cactus....
