February 10, 2026, 04:27:04 AM *
Author Topic: forward saddle bag bolt  (Read 1281 times)
N0tac0p
« on: April 08, 2015, 03:28:57 AM »
item 45 on the fiche, its a 10 x 70,  but I seem to remember the thread as being difficult to find.  was it a fine thread (20) or a coarse thread (14).  anyone know
« Reply #1 on: April 08, 2015, 04:02:15 AM »
Take the right side out, see if it will fit in the left side.
If so, go to ACE Hardware and buy a replacement.
Problem solved.
« Reply #2 on: April 08, 2015, 04:28:56 AM »
Problem solved.
mustang071965
those that dare, Succeed.
monticello Ar
« Reply #3 on: April 08, 2015, 04:35:21 AM »
10x70 metric. 10mm shaft by 70mm long. most all 10mm bolts are either 1.25 or 1.5 thread pitch.
« Reply #4 on: April 08, 2015, 05:01:33 AM »
If your near a Rocky's Hardware, they have a large selection of metric fasteners with some chrome stuff also.
N0tac0p
« Reply #5 on: April 08, 2015, 05:02:20 AM »
thx both.  I understand the 10 mm comes in fine and coarse,  hoping somebody remembers as I am old and forgetful
« Reply #6 on: April 08, 2015, 05:18:49 AM »
The 10mm is a 1.25 pitch, fine thread. The 8mm is also a 1.25 pitch which is a standard thread for an 8mm.
N0tac0p
« Reply #7 on: April 08, 2015, 05:22:04 AM »
THAT"S IT Sandy...
the 8 fine thread is std, the 10mm std is coarse is std, so I had a hard time finding the 1.25
« Reply #8 on: April 08, 2015, 05:56:53 AM »
Problem solved.
If the  left is out and you remove the right as well....POW that's when all the parts go out of alignment...WATCH IT
N0tac0p
« Reply #9 on: April 08, 2015, 06:08:15 AM »
so now where can I find 10 x 70 x 1.25 chrome studs and acorns (or I guess stainless),  any clue.  ie I am setting up my bags to be quick drop
« Reply #10 on: April 08, 2015, 06:39:37 AM »
I have an Ace hdw here in town and abut 23 miles away a farm supply. Both have a really good selection of metric in a bright plating and a true chrome plating. OR you can see if your Honda dealer an get you what you need. Missing bolts on a Sunday and I'm at the hdw store.  2funny I've also heard that Home Depot and Lowes have some metric hdw. Hope this s of some help! RIDE SAFE.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #11 on: April 08, 2015, 06:52:42 AM »
I couldn't find them anywhere, local or online.  A few places pretend to offer them but when pressed, can't produce.
Anything that is long enough is a shoulder bolt which won't work in that forward position since there is threaded boss on the inside of the fender and that's where the shoulder would end up if you insert from the inside.
So, I used 3/8 (9.53 mm) steel rod and a 1.25 metric die to make studs.  Slow going, but successful.
Coat it well with antisieze and it won't rust in place.
« Last Edit: April 08, 2015, 11:29:49 AM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #12 on: April 08, 2015, 02:37:27 PM »
Problem solved.
Not if it is a saddlebag bolt. All it holds is the saddlebag.
« Reply #13 on: April 08, 2015, 02:44:42 PM »
Problem solved.
You're right, my bad....I was thinking saddlebag mount bots which are the same as the fender rail bolts.....
« Reply #14 on: April 08, 2015, 03:21:16 PM »
Yes I totally agree made that mistake before removing the fender rail bolt that is 2funny uglystupid2 uglystupid2
blackvalkyrie
California
« Reply #15 on: April 08, 2015, 03:44:53 PM »
hey Bighead:
I gotta question.. I know you have Jumbo Strong bags on your bike. I just got mine, but the bolts that I got don't fit into the front bolt hole on the fender rail, and the nut on the back is a different size/pitch.  Did you have to buy bolts or do any mods on the fender rail? My mounting bolts ( 4 ea) did not come with any nuts.
Problem solved.
Valkpilot
Corinth, Texas
« Reply #16 on: April 08, 2015, 05:13:51 PM »
I believe we are talking about the forward fender/fender rail/saddlebag support bolt.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #17 on: April 08, 2015, 07:38:03 PM »
hey Bighead:
Problem solved.
My bags are actually OEM 1999 Interstate bags coolsmiley
« Reply #18 on: April 08, 2015, 08:09:27 PM »
In 6 years I have never found those acorn nuts that Honda used on their motorcycles. Only regular chromed ones without that flared washer on the bottom. My ACE T had a few rusty ones, so I just removed them all and replaced with standard ones instead. Looked better than the rust.
« Last Edit: April 08, 2015, 08:20:40 PM by gordonv » Logged
« Reply #19 on: April 08, 2015, 08:40:19 PM »
hey Bighead:
Problem solved.
I think you are confusing Bigheads bike with Panchos bike. A different yellow & black. cooldude
blackvalkyrie
California
« Reply #20 on: April 09, 2015, 07:46:21 AM »
Thanks meathead!
hey Bighead:
Problem solved.
