February 10, 2026, 06:11:12 AM *
Author Topic: Interstate radio just stopped working?  (Read 1309 times)
Rdcd
« on: April 09, 2015, 10:12:07 AM »
 My radio and screen display just stopped working on my 2000 interstate? The fuel gauge on the display monitor is still working but nothing else. No clock or radio. I would be very grateful for advise what it may be?  It always worked fine. Then one day it stopped working when I started it up. Thanks in advance for any help.  Ray
Rdcd111@AOL.com
« Reply #1 on: April 09, 2015, 11:41:20 AM »
That is symptom of dead or dying alternator as well
check fuse 1st then put volt meter on bike to see if charging 14v
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #2 on: April 09, 2015, 11:42:54 AM »
I've never had an Interstate and always wanted one. I quess I could tell you that this is the 1st sign of it's total failure and I can offer scrap pricing to take it off your hands, but I'm sure you would see right thru that. That all being said and since I've never had one, have you checked fuses? Don't know f the radio is fused alone or not.
Williamsburg, KY
« Reply #3 on: April 09, 2015, 11:43:48 AM »
You beat me to it as I'm a slow typer  Cheesy
BigBad1
1999 Interstate
Garner NC
« Reply #4 on: April 09, 2015, 11:58:12 AM »
I have read of a few people having the same issue and found that it was a corrosion inside a connector under the battery box. I did a quick search and found this old link. Be sure to check your fuses first.
http://www.valkyrieforum.com/bbs/index.php/topic,23859.msg211347.html#msg211347
Let us know what you find.
« Last Edit: April 09, 2015, 12:20:00 PM by BigBad1 » Logged
72cutlassdude
99 Super Valk VRCC 35563
Laingsburg, MI.
« Reply #5 on: April 09, 2015, 12:37:30 PM »
Check the 5amp fuse (i think) in the small fuse box next to the main one under the right side cover.
"Common sense is not a flower that grows in everyone's garden"
Novavalker
99 Interstate/2017 Goldwing
« Reply #6 on: April 09, 2015, 12:59:11 PM »
Rdcd111@AOL.com
I emailed you a document that will likely solve this electrical gremlin.
mustang071965
those that dare, Succeed.
monticello Ar
« Reply #7 on: April 10, 2015, 04:31:52 AM »
had the same happen on my IS last year. the problem was the connector under the battery box. it was corroded. pulled battery and box opened and cleaned the connector. applied Dio grease to all connector points then sealed the plug with elect tape.
Novavalker
« Reply #8 on: April 10, 2015, 07:21:28 AM »
Sometimes the pins inside the plug are too corroded and beyond repair. When that happens the plug has to be cut out and wires spliced IAW the document that I have been passing around.
PAVALKER
Pittsburgh, Pa
« Reply #9 on: April 10, 2015, 07:30:20 PM »
Any way too at this document?
John
Novavalker
« Reply #10 on: April 11, 2015, 01:38:17 AM »
Just send me a PM and I'll email it to you.
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #11 on: April 18, 2015, 12:04:53 PM »
If it s not the connector as described above --- I have two interstates and I am a plane Jane - I took the radios off and with it the left side radio control switch box and then put on new clamps form the right side brake. When the radio comes out the only thing that is displayed is the gas gauge. Juśt the way I like it.  So it sounds like the radio. Seems there are plenty on EBad if not PM me I will give up mine and the controls.  Can't hear the music over 50 mph anyway. I'll stick to machanical music.
« Last Edit: April 18, 2015, 12:10:17 PM by Sheffjs » Logged
Steve K (IA)
Cedar Rapids, Iowa
« Reply #12 on: April 19, 2015, 04:11:50 PM »
Did he get the control box wet whether in the rain or a wash?  If that box gets wet, you won't have a radio until it dries out.
States I Have Ridden In
mustang071965
monticello Ar
« Reply #13 on: April 20, 2015, 04:16:03 AM »
had the same problem on my IS last year. it turned out to be the plug under the battery box. it was corroded. i was able to clean all the connectors and apply electric contact grease to it then sealed and tapped the plug. good to go now.
Big Rig
Woolwich NJ
« Reply #14 on: April 20, 2015, 08:12:35 AM »
HAd the same problem, fuse blew when i plugged in my intercom...short in the intercom due to corrosion...cleaned it and replaced the fuse...good to go...(99 IS)
