February 10, 2026, 04:28:39 AM *
Author Topic: where to order starter clutch  (Read 1184 times)
three wheeler
« on: April 09, 2015, 05:38:49 PM »
Hi
The dealer is quite pricy and doesn't have in stock.  If I'm going to order any ways is there someone, or somewhere online to order them cheaper??
Thank's John a newbie
surprised a lot of online parts stores don't even show the Valkrie when I look up models
« Reply #1 on: April 09, 2015, 05:42:09 PM »
http://www.procaliber.com/
Pappy!
Central Florida - Eustis
« Reply #2 on: April 09, 2015, 06:32:20 PM »
You asked the same question in the Florida forum. We are trying to help you there.
Question has been answered there as well as several suggestions. Go read 'em!
« Reply #3 on: April 09, 2015, 06:39:47 PM »
Just got off the phone with him, he was expecting to see Valkyrie listed but advised him they're listed as GL1500 with different subs at the end for the models. I got him on the Procaliber site so he now can look up stuff. Also told him regardless of the problem; starter clutch or hydrolock troubles, it involves pulling the engine and a lot of money if he lets a shop do it. Said he might be better off replacing the engine for less $$ than fixing the current one with well over 100k on it. No problem with a high mileage engine, just looking at the cash outlay comparison; fix or replace.
« Reply #4 on: April 10, 2015, 06:23:11 AM »
Don't see any such animal as a starter clutch on the Fische.
« Reply #5 on: April 10, 2015, 07:17:01 AM »
 this is it
#12
GEAR ASSY.
31210-MW5-871
I was wrong , this is it, also listed for the GL1800
# 18
CLUTCH OUTER, STARTING
28125-MN5-014
http://www.partzilla.com/parts/search/Honda/Motorcycle/1998/GL1500C+A/PRIMARY+DRIVE+GEAR/parts.html
JohnS
pg 10-13 shows where its at and for removal, section 18 as u noted does show it on page 18-15
« Last Edit: April 10, 2015, 02:47:02 PM by CA » Logged
« Reply #6 on: April 10, 2015, 08:49:30 AM »
Yup, it's there, mounts on the back of the engine just above the clutch basket. Check section 18 in the shop manual.
three wheeler
« Reply #7 on: April 10, 2015, 11:32:15 AM »
thank you for your help and suggestions.  You were right it was hydra locked.  Pricing both replacement and repair.  Will know more by next week.  Cross you fingers for me.
« Reply #8 on: April 10, 2015, 05:25:56 PM »
John, if it were me I'd go for that engine link I sent you in a PM. Go get it with a trailer and save shipping. For the price of that engine, you can't fix yours. Seriously!   cooldude
John
« Reply #9 on: April 10, 2015, 05:29:12 PM »
get a '97-00 goldwing GL1500 engine. better OD gears than the valkyrie, engine bottom end is the same, then just swap heads and carbs.
three wheeler
« Reply #10 on: April 10, 2015, 07:25:41 PM »
thank you
« Reply #11 on: April 10, 2015, 07:42:33 PM »
How about the wiring harness? Can you use the Valks ?
