February 10, 2026, 04:27:05 AM *
Author Topic: Harbor Freight MC tire changer question...  (Read 1017 times)
Whooray
Idaho State Rep
Kuna, Idaho
« on: April 10, 2015, 07:49:42 AM »
Some of you have adapted the tire changer to work on our wheels .... question, what did you use  in place of the rod that came with the adaptor. I bought a 3/4 in steel rod and had to grind it down a bit to fit,. I just want it to work right.
Raymond (Whooray) Hill
Vietnam Vet 6/68 - 1/70
919th Combat Engineers
11th ACR (Blackhorse)
quexpress
Montreal, Québec, Canada
« Reply #1 on: April 10, 2015, 08:17:03 AM »
Is this what you have done? I have done this mod on mine years ago and can tell you that it works very well!  cooldude
I still have a full deck.
I just shuffle slower ...
Whooray
Idaho State Rep
Kuna, Idaho
« Reply #2 on: April 10, 2015, 10:28:48 AM »
What materal is the black rod you installed and is it threaded, if so what thread size?  Raymond
Right now have just put a 3/4 rod 3 feet long without threads in place had to grind down the end to fit. It looks like what you have done is what Im looking to do.
mike72903
« Reply #3 on: April 10, 2015, 11:13:11 AM »
I put a 3/4 inch threaded rod from Lowes.  Works fine.  On another note I just ordered a mojo lever and blocks.  The demount rod from HF truly sucketh.
quexpress
« Reply #4 on: April 10, 2015, 04:51:04 PM »
That pic is not mine but am set-up the same way.
I, like you, have used a generic 3/4-inch rod purchased at the hardware store. I did not need to grind it down.
With the top inverted-L shape removed, this now permits me to walk around the tire changer while installing/removing tires.
longrider
Vernon, B.C. Canada
« Reply #5 on: April 11, 2015, 03:36:41 PM »
I purchased the same setup last year.  I cut off the original thread that came with the center rod and welded a 3/4 inch rod to it. Run it through the wheel from the bottom and thread it in.  Then I changed things up a bit.  The HF changer has only one adjustable shoe.   I pretty much copied the one so that all three can move and be snugged up to the rim.  The wheel can be centered and the rod can be used but I found out it is not really needed once the three can be tightened.  I also sandwiched a 3/4 in piece of hard rubber in between two pieces of 1/2 nylon on each of the three movable legs to grip the rim securely and protect it from scratches.  A Nomar tire bar and the job is easy now.
quexpress
« Reply #6 on: April 11, 2015, 03:48:04 PM »
Very interesting!  cooldude
Do you, by any chance, have any pics of these 2 mods?
Thanks!  Cool
« Reply #7 on: April 11, 2015, 05:23:58 PM »
Thanks!  Cool
Yes! Pics please.?  ???
My rides:
mike72903
« Reply #8 on: April 12, 2015, 08:55:02 AM »
"The wheel can be centered and the rod can be used but I found out it is not really needed once the three can be tightened. "
I'm confused by this.  Are you referring to the center rod that threads through the tires center ?
quexpress
« Reply #9 on: April 12, 2015, 01:32:12 PM »
Correction:
I have done this mod quite a while ago and was wondering why I didn't have problems with the threads.  Shocked
It's because I have used a 5/8-inch rod. It is dropped down into the middle hole and is then held tight by the knob/bolt on the side of the triangle frame lower pipe.
Sorry about the misinformation ... my memory ... it's great but sometimes forgets.  uglystupid2
