February 10, 2026, 04:28:38 AM *
Author Topic: Clutch fluid leaking from the slave housing  (Read 1164 times)
Bonzo
« on: April 11, 2015, 07:22:06 AM »
That housing should be dry i think. time to rebuild the slave cylinder i think
« Last Edit: April 11, 2015, 08:58:18 AM by Bonzo » Logged
Woops, I'm sorry.
Bonzo
« Reply #1 on: April 11, 2015, 09:00:30 AM »
Woops, I'm sorry.
pancho
Bonanza Arkansas
« Reply #2 on: April 11, 2015, 10:59:30 AM »
I agree,, if you just buy #9, make sure you put it on in the same direction the original one is.
http://www.partzilla.com/parts/search/Honda/Motorcycle/1997/GL1500CT+A/CLUTCH+COVER/parts.html
« Last Edit: April 11, 2015, 11:01:05 AM by pancho » Logged
Bonzo
« Reply #3 on: April 11, 2015, 11:25:49 AM »
Yes thank you. I was chatting with Bill Big BF Ferguson. I think I got lucky with the Bleeding valve just getting loose. I cleaned everything up, checked everything tight, Bled the system and i had clutch!
Woops, I'm sorry.
