February 10, 2026, 09:36:46 AM
Corbin side covers
Topic: Corbin side covers (Read 1396 times)
Joevalk
Santa Fe, Texas
Corbin side covers
April 13, 2015, 06:37:35 PM »
Does anyone have any pics of the mounting brackets? Seams my painter has misplaced them.
Still posses I won't be at the GOTFs
VRCC#32720
1999 Grn/Silver Interstate
Joevalk
Santa Fe, Texas
Re: Corbin side covers
April 13, 2015, 08:14:57 PM »
http://www.quexpress.02hosting.com/quexpress/Valkyrie/side_cover.htm
Found some info
VRCC#32720
Dusty
Mill Bay B.C.
April 14, 2015, 03:23:55 PM »
Did you get enough info . I have one in the garage that I can take a picture of if you need it. Let me know
Dusty
Joevalk
Santa Fe, Texas
April 14, 2015, 04:03:04 PM »
Measurements would be more helpful, I may have to make my own
And pics too. Thanks
VRCC#32720
Dusty
Mill Bay B.C.
April 14, 2015, 04:50:03 PM »
For the right side cover(when sitting on the bike) there is a bolt, lock washer, 2 rubber washers, a sleeve that slides over the bolt, a nylock nut and a chrome nut.
The bolt is metric so I will give metric sizes and conversions 6mm x 1 mm pitch x 50 mm long threaded all the way to the end of the bolt. hex head is 10 mm
Bolt diameter in inches is .230 " x 1.961 long . hex head is 3/8"
rubber washers are 1/4" hole x 5/8" outside diameter x 3/32" thick each
Metal sleeve is 1/2" od x 1/4" hole x 1" long material steel.
Acorn nut is 11 mm hex 16mm long
Acorn nut is 7/16" hex and 5/8" long.
I don't know where the bracket is for the left side cover so I sent an e-mail to a friend to measure his. I will post up the rest of the info when I get it. Any questions?
Dusty
Dusty
Mill Bay B.C.
April 15, 2015, 11:42:22 AM »
Joevalk
I talked to Normand (Quexpress) and he says the hardware is the same for both sides. So just double up on the right side hardware and your good to go.
Dusty
Joevalk
Santa Fe, Texas
Reply #6 on:
May 18, 2015, 11:31:33 AM »
Have you ever missed placed something, right where you left it? Well I have. Found my mounting hardware in drawer
I forgot.
VRCC#32720
