February 10, 2026, 04:26:52 AM
progressive 416 shock parts
Topic: progressive 416 shock parts (Read 701 times)
matt
Derry New Hampshire
April 14, 2015, 04:10:12 PM »
Hello, Not sure if anyone can answer these questions for me, I emailed progessive and have not heard back. I have found the seals I need new boots (were to buy?) also does anyone know if the vtx, red eye or Daryls bushings would fit the progressive the top and bottom bushing are the same? as the bottom one with thin collar is beat. Thank You so I removed top and lower bushing inside hole appears to be 5/8 I am guessing inside would be same as it uses stock bolts to mount, all four bushings are the same. They are beat bad but outside (part that would be pressed ) is just shy of an inch. Length looks like 5/8 on inside edge of lip that stays outside of eyelet. May not be best explanation but I dont have a stock one to compare.
Last Edit: April 15, 2015, 03:35:27 PM by matt
Re: progressive 416 shock parts
April 14, 2015, 04:28:22 PM »
I just pressed a Progressive bushing out of a 440HD. They're not the same as a Valk bushing. Wait for Prog to answer.
