August 02, 2025, 07:52:26 AM
1800 Tech Board
Factory Bags
Topic: Factory Bags (Read 3098 times)
GA VALK
Factory Bags
April 16, 2015, 04:54:47 PM »
Can you install the factory hardware & bags and ride without the rear seat and pillion grips?
maddoggie501
Re: Factory Bags
April 17, 2015, 08:31:24 AM »
I have the factory bags and they do require the hand rails to mount. However, you can get rid of the rear seat.
maddoggie501
Re: Factory Bags
April 17, 2015, 08:33:31 AM »
I may stand corrected, look up the bag mounts on Honda's accessory page. There may be a mount to use without the hand guards. My mount bolts to the passenger hand guards
mrtappan
Re: Factory Bags
April 17, 2015, 09:30:19 AM »
They make both. I bought both sets because I wasn't sure which I would use. Also, you can mount non-Honda bags to their mounts. The mounts are flat so any bag that covers it should work
Profile deleted.
GA VALK
Re: Factory Bags
April 18, 2015, 08:54:32 AM »
THats good news
Thank you
mrtappan
Re: Factory Bags
April 18, 2015, 09:35:50 AM »
Granted, I'm sure the OEM Honda bags are reinforced so they support the weight on the contents.
If you use an aftermarket bags like Saddlemen you may have to make a template for the inside. On my bikes when I used EZ-Brackets, I would take a 1/4" thick piece of wood and trace the outside of the bag on it. Then cut about 1/2" or so inside the trace to make in inner piece for the bags. I went across country four times on a bike with Extra Jumbo Saddlemen bags loaded down with all kinds of junk. They never tore or had any problems so I trust that method.
Profile deleted.
=> InZane XXV
