February 10, 2026, 06:11:11 AM *
Author Topic: turn signal problems  (Read 1024 times)
whonneb
« on: April 20, 2015, 04:18:12 PM »
I think that my turn signal relay has gone out. My left turn signal is solid and my right turn signal blinks. I removed all of the bulbs on the left side thinking I had a short of some kind, one by one, with change. Has anyone ever had this problem? Also does anyone have the part number for the relay?
« Reply #1 on: April 20, 2015, 04:30:48 PM »
Sounds like it could be a ground issue, check your ground wires in the headlight for starts.
« Reply #2 on: April 20, 2015, 04:32:15 PM »
RELAY, TURN SIGNAL (MITSUBA)
38301-KK9-952
$50.11
$36.93
big poppa pump
San Antonio, TX
« Reply #3 on: April 20, 2015, 04:53:00 PM »
Forget the OEM relay. Get an electronic relay for 10 bucks from your local auto parts store.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Jack B
Two Rivers Wis
« Reply #4 on: April 20, 2015, 04:55:33 PM »
You could also try cleaning out the switch under the handlebar housing..
Let’s RIDE
« Reply #5 on: April 20, 2015, 05:32:19 PM »
This would be my first fix attempt. The old dry grease can cause many weird symptoms.
rhinor61
Northern California
« Reply #6 on: April 21, 2015, 02:46:04 PM »
Okay first off..
The right side works fine, flashes normally.
Left side does not flash, but light stays on.
correct?
If so, rule OUT a bad RELAY... ( there is only ONE relay, so if works for 1 side and not the other its not the relay)
You have a grounding issue, either bad bulb or corrosion in the socket or else where...
I would swap the left side bulb with the right side bulb... Front is an 1157 and the rear are 1156.
Dont try new bulbs at this time..
Does the problem stay on the left side or did it swap to the other side?
please reply back.
John
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
« Reply #7 on: April 23, 2015, 09:47:54 AM »
If it's the front, replace the bulb if needed. Did you check the bulbs, that's usually the first step.  Front and rear bulbs are different from each other, will not work right if switched. I agree with the previous post.  Hoser  ???
« Last Edit: April 23, 2015, 09:49:40 AM by Hoser » Logged
pancho
Bonanza Arkansas
« Reply #8 on: April 23, 2015, 04:59:52 PM »
Check your bulbs, then clean up the handlebar switch as was mentioned by Jack B and sandy,, I have had those same symptoms and the switch was causing it. The washing out of the switch fixed it for awhile, then I needed to do it again at a later date.
