February 10, 2026, 06:10:05 AM *
Author Topic: 1998 F6 1500 C OEM windscreen replacement  (Read 2914 times)
f6 white buffalo
1998 F6 ....shes perdy
Connecticut
« on: April 21, 2015, 08:12:34 AM »
OEM replacement windscreen..
hey guys need some advice..
an being told by my local dealer that the OEM windscreen for my 1998 is unavailable. Cant get them anymore
what is a suitable re[placement that gives similar wind coverage as the monster shield I have now
I am well protected back there and dont want to make a mistake in picking something I wont like
I have ridden in 50 degree weather with a t shirt on behind that screen and wasn't cold ..
hard to get that with a smaller shield .....anyone know where any OEM shields are hiding ....thanks for your input
« Reply #1 on: April 21, 2015, 08:32:17 AM »
Try Clearview for a OEM-style replacement shield...
OEM-style as in: it will fit on the OEM hardware.
not OEM-style as in: made of different stuff, thicker, nicer (I think)...
Joe Hummer
Arnold, MO
« Reply #2 on: April 21, 2015, 09:04:50 AM »
I looked through your past posts but didn't see which model you had.  If you have the Tourer (has hard saddle and factory windshield like the one shown at this site:  Windscreen), I would go with a Clearview like previously offered.  Top quality, a bit thicker than stock, same mounting.  You just replace the plastic and go.
If you have a Standard with an aftermarket windshield, then you will have to either replace everything (plastic and mounting frame) with a unit of your preference (such as Memphis Shades) or contact the manufacturer of your shield and ask for a replacement shield for your frame.
Hope this helps.
1999 Valkyrie Interstate
« Reply #3 on: April 21, 2015, 05:05:51 PM »
Since you say it's a 98, I assume it's a standard or  tourer. Check these out, they use the OEM hardware.
http://www.ceebaileys.com/honda/valkyriews.html
http://www.clearviewshields.com/motorcycle-windshield/honda/valkyrie-std-tourer-shields/
If you don't want to use the original hardware, check into what Memphis Shields has to offer.
http://www.memphisshades.com/metric-shades
My rides:
« Reply #4 on: April 21, 2015, 06:17:28 PM »
F4 Customs used to offer shield replacements for the tourer/standard, but they seem to only offer replacement shields for the Interstate now.
https://www.f4customs.com/
Salty posted the links to the only other known suppliers of aftermarket replacement shields for the tourers and standards now.....CeeBailey's and ClearView.
« Reply #5 on: April 21, 2015, 06:27:17 PM »
Hard to beat Ceebailey's  cooldude
Paladin528
« Reply #6 on: April 22, 2015, 09:47:45 AM »
I found a guy not far from me that takes your original windshield and uses it as a template to cut you a new one.  Doesnt handle windshields with compound curves or anything but the end result is pretty good and fits with the OEM hardware.
