February 10, 2026, 06:11:06 AM *
Author Topic: Tripple Tips on an Interstate  (Read 752 times)
72cutlassdude
99 Super Valk VRCC 35563
Laingsburg, MI.
« on: April 23, 2015, 07:38:41 AM »
Can anyone tell me if the tripple tip exhaust ends will work on an Interstate? Thanks!
"Common sense is not a flower that grows in everyone's garden"
« Reply #1 on: April 23, 2015, 07:40:21 AM »
You'd have to at least cut your piggies.
72cutlassdude
Laingsburg, MI.
« Reply #2 on: April 23, 2015, 07:48:15 AM »
Thanks Mike! That's kinda what I thought but wanted to be sure.
Cliff
Manchester, NH
« Reply #3 on: April 23, 2015, 09:12:22 AM »
I put these on my interstate w/o cutting the piggies..... I inserted tightfitting long dowels into all three piggies and used the dowels to guide the piggies into the new position forced by the sliding on of the triple tips, once the triple tips were on I just pulled the dowels out and moved on to do the other side.  Worked well and with a little bending can always go back to stock tips
NOTE: The dowels need to be long enough to protrude through the triple tips before they reach the ends of the piggies, that way each dowel is already in the triple tip hole that you need the corresponding piggy to go into.
« Last Edit: April 23, 2015, 09:14:46 AM by Cliff » Logged
VRCC # 29680
indybobm
Franklin, Indiana VRCC # 5258
« Reply #4 on: April 23, 2015, 09:21:08 AM »
If you can't use these I would be happy to buy them from you!
So many roads, so little time
VRCC # 5258
