February 10, 2026, 06:11:00 AM *
Author Topic: What does it do ??  (Read 1180 times)
knockdolian
« on: April 26, 2015, 12:27:42 PM »
Hi all, Just a quick question. I gave the Interstate a good clean today. Only had it three weeks and this was the first good clean. What's the leaver on the bottom of the top trunk.it doesn't seem to be attached or do anything. Rear left under the trunk  Undecided
« Last Edit: April 26, 2015, 01:18:48 PM by knockdolian » Logged
« Reply #1 on: April 26, 2015, 12:42:29 PM »
Its supposed to be the release to open the lid.  You can see it in the microfishe, #24 its called "Lever, Lid Opener"
http://www.procaliber.com/oemparts/a/hon/506c2f9cf870023420a31bf9/trunk-box
« Reply #2 on: April 26, 2015, 01:14:08 PM »
It will only work if the trunk is unlocked also. Put your key in turn switch (not the way it opens it but opposite) then remove key and try and see if it works.
knockdolian
« Reply #3 on: April 26, 2015, 01:23:45 PM »
Just tried it, would never have worked that one out. Thanks very much
SpidyJ
Murrells Inlet
« Reply #4 on: April 27, 2015, 04:46:12 PM »
Just curious......didn't you try to look in the trunk b4 you bought it?
 2funny Cheesy
1999 Fast Black Interstate
Peace,
johnnywebb
« Reply #5 on: April 27, 2015, 05:14:40 PM »
 2funny Cheesy
Probably just opened it with the key as I did when I first got an Interstate. coolsmiley
knockdolian
« Reply #6 on: April 28, 2015, 11:56:27 AM »
Yep, just opened it with the key. The nice shiny new key that only fits the top trunk as the PO locked his bike keys in the trunk by putting it in his glove and shutting the lid  Roll Eyes I have the Honda hand book and that doesn't mention what  its for
« Reply #7 on: April 29, 2015, 07:27:20 AM »
For what it's worth, if your ignition key will slip into that trunk lock (meaning the offsets are the same orientation), a good locksmith can rekey it so one key will do both.
knockdolian
« Reply #8 on: April 29, 2015, 10:54:17 AM »
Thanks, Ill look in to that
