February 10, 2026, 06:11:04 AM *
Author Topic: rear axle?  (Read 824 times)
mike72903
« on: April 29, 2015, 01:12:43 PM »
Searched but didn't see anything. Does the rear axle get a coat of grease before installation?  I'm guessing not but don't want to have to remove it again.  Thanks
« Last Edit: April 29, 2015, 01:14:22 PM by CI_borg » Logged
« Reply #1 on: April 29, 2015, 01:19:12 PM »
It doesn't spin or anything.
I put a light coat on there so it slides in and out easy, but not so much
that you end up with a big blob of scraped-off grease after you
push the axle through...
mike72903
« Reply #2 on: April 29, 2015, 01:21:31 PM »
What I thought. Thanks Mike
« Reply #3 on: April 29, 2015, 04:10:30 PM »
The grease should be waterproof too. I've seen a pro mechanic use a huge punch and sledge hammer to get an axle out of a VTX 1800. The grease prevents rust and pitting on the axle.
« Reply #4 on: April 29, 2015, 04:24:49 PM »
YES!  I think my axle and internal spacer had a different metal reaction; there was a light powdery corrosion.  I steel wooled it clean and shiny, and always lightly grease on reassembly.
Always assume water will get into everything, even if it's not supposed to.
« Reply #5 on: April 29, 2015, 04:53:31 PM »
consider silver anti-sieze instead. grease can dry out and still allow corrosion. AS does not dry out and provides a water barrier. just search its benefits.
If I want corrosion protection anti-sieze is what I use
Earl43P
Farmington, PA
« Reply #6 on: April 29, 2015, 05:24:58 PM »
I smear the moly 60 paste that got all over my vinyl gloves on it /shrugs/.
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
« Reply #7 on: April 29, 2015, 05:42:43 PM »
 cooldude cooldude
Brian
Monroe, NC
« Reply #8 on: April 29, 2015, 06:24:04 PM »
Yep, grease the shaft. No problem removing it year after year. I think anything is better than nothing. I like the anti-seize idea. I have been using the dark green Lucas X-tra heavy duty grease that is suppose to be good against wash out. So far so good.
