February 10, 2026, 07:46:15 AM *
Author Topic: back firing and popping in #1 carb only  (Read 1032 times)
rainman
Steve ( rainman) Eads
Bloomington Indiana
« on: May 01, 2015, 08:39:37 AM »
not sure what the problem is but I hope it is not what I think it is.
the problem is at about 1500 rpms the #1 carb front right carb is popping i have checked the vacuum and no leaks also put a new plug in still the same.  The only thing i have not done is to and see it might be out of sink.
any help would be good
Thanks in advance
« Reply #1 on: May 01, 2015, 08:48:05 AM »
Thanks in advance
Out of SINK huh....lol   Carburetor synchronization only is important for idle and initial accelerations.   Once all six slides are moving sync is a non issue so the popping at 1500 is most certainly caused by something else.  Id recheck the vacuum plug on that intake nipple.  Sometimes they look good but are dry rotted and leak.
Also did you check the exhaust, lose header nuts can cause this.
And did you check all the intake runner clamp screws?
If all that checks out Id run some strong techron or B-12 and see what happens
rainman
Bloomington Indiana
« Reply #2 on: May 01, 2015, 08:54:45 AM »
hep header nuts are tight and intake clamp screws are tight. one thing i forgot to say is that if i pull the chock about half on it goes away
« Reply #3 on: May 01, 2015, 08:58:13 AM »
What did that spark plug look like when you pulled it?  The choke (enricher) significantly richens up the mixture, if #1 is running lean it would like the enricher so maybe all you need is an air screw adjustment.
rainman
Bloomington Indiana
« Reply #4 on: May 01, 2015, 09:19:34 AM »
spark plug looked good but i did replace it with a new one
Punisher
No, not vengenance. Punishment.
« Reply #5 on: May 01, 2015, 11:24:52 AM »
Have the o-rings under the carb tubes ever been replaced?    Bolts on the carb tube snug?   Be careful, I think the torque on those is very light, like 6-7 ft lbs.
No sign of leakage around it (a yellow/brownish residue)?
pocobubba
Pocomoke , Md
« Reply #6 on: May 01, 2015, 01:12:27 PM »
Check the slide diaphragm for a tear or hole
rainman
Bloomington Indiana
« Reply #7 on: May 01, 2015, 01:16:54 PM »
Punisher O-rings have never been replaced but there is no yellowish brown on heads did check to see if they had loosen up but they were tight going to run some teckon b-12 and see if that makes any changes. if not I am in the work of making a tool to reset the carb.
rainman
Bloomington Indiana
« Reply #8 on: May 01, 2015, 01:18:56 PM »
where the hell is the slide diaphragm at never heard of that animal
signart
Crossville, Tennessee
« Reply #9 on: May 01, 2015, 02:03:54 PM »
Actually I think he means vacuum piston. The rubber part under the chrome cap, then black cover on top of each carb. Easy to tear or get misaligned when fooling with it. Good thing to check, will cause popping. Real cheap too, you'll be very careful with them after you buy one.
pocobubba
Pocomoke , Md
« Reply #10 on: May 01, 2015, 02:23:33 PM »
You are correct Signart vacuum piston is the proper term . I've never had problems on my Valks but have had problems on other bikes , same symptoms .
rainman
Bloomington Indiana
« Reply #11 on: May 01, 2015, 02:47:11 PM »
now I know what you are talking about will have to check it should be ok never have had the caps off but I guess that don't meant it couldn't be mad
