February 10, 2026, 07:46:09 AM *
Author Topic: Allen bolt slot finishers  (Read 983 times)
cogsman
Newmarket, Ontario, Canada
« on: May 03, 2015, 05:14:56 PM »
Hi All,
Not even sure if I'm calling these by the right name. I'm noticing that my cylinder head cover mounting bolts on the left bank have little metallic-like plugs (plastic I'm assuming) that hide the hex slot. The right bank is missing those. Looking around, there are plenty of other hex slots; some are covered, some are not.
Now that I've noticed this, it's driving me crazy. I guess I just love symmetry!
Where can I get these inserts (preferably without having to mortgage my house in the process)? 'm seeing bolt caps on eBay, mostly for Harleys, but not looking for those anyway. Not sure what I'm supposed to be searching for.
« Reply #1 on: May 03, 2015, 05:35:53 PM »
Got mine at Ace Hardware, they usually have a good assortment and not super expensive. Yes, they are plastic, I put a dab of RTV on them to make sure they didn't fall out.
SteveBC777
2000 tourer red/black {minus screen}
Pattaya Thailand
« Reply #2 on: May 03, 2015, 05:51:43 PM »
" Now that I've noticed this, it's driving me crazy. I guess I just love symmetry! "
Easiest, and of course the cheapest answer, is remove the ones from the left hand side and put them in your spares drawer.
Job done.......
Spannerman to some of the nicest chaps you could ever wished to of met .
cogsman
« Reply #3 on: May 03, 2015, 05:58:11 PM »
Great! What are they properly called?
BobB
« Reply #4 on: May 03, 2015, 06:04:38 PM »
I believe the OEM plugs in the cylinder head covers were black soft plastic.  I'm lucky that I still have all of mine.  I have covered other Allen head bolts with chrome plated steel hole plugs.  I guess I am also one of those symmetrical dudes.  I have also replaced bolts with chrome bolts.  The source I have used is http://www.chromebolt.com.
« Reply #5 on: May 03, 2015, 06:23:04 PM »
Chrome metric allen bolt hole plugs. (I am unsure of size for the valve covers)
Plastic or stainless or chrome plated steel.
https://www.boltdepot.com/Metric_hole_plugs_for_socket_caps_Chrome_plated_steel.aspx
http://www.ebay.com/itm/chrome-bolt-cap-screw-cover-hole-plug-M8-bolt-6mm-allen-key-x6pcs-USA-STOCK-/400813983927
« Last Edit: May 03, 2015, 06:29:25 PM by Jess from VA » Logged
Dusty
Mill Bay B.C.
« Reply #6 on: May 03, 2015, 08:57:59 PM »
 I have heard them called snap caps
Dusty
« Reply #7 on: May 04, 2015, 04:44:05 AM »
I still have all of mine... but I've wondered about it...
What if you just neatly filled the hole with black RTV?
Would it be much different than a real one after it
sets up?
Bambam650
Cincinnati, Ohio
« Reply #8 on: May 04, 2015, 06:23:18 AM »
Wow, just checked the price of the OEM rubber plugs from HDL and they are $3.80 a piece.  I still have all of mine from when I bought my bike new back in August 1996.
1997 Standard (Black) original owner, bought new in August 1996
Bambam650
Cincinnati, Ohio
« Reply #9 on: May 04, 2015, 06:29:45 AM »
sets up?
That should work.  You could even wipe a little oil on the inside of the socket before filling it so it would be easier to pull the plug out when you need to.  I actually prefer the contrasting look of the black against the chrome like the OEM plugs.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #10 on: May 04, 2015, 10:02:40 AM »
sets up?
I have had the same thought.  I think I found 3-4 missing.  When I discovered that, I pulled the rest.  Don't remember where I put them.  I am sure while drying the bike after washing, my towel pulled them out.
Maybe I'll get the black RTV out.   Wink
States I Have Ridden In
PharmBoy
Lawton, Ok
« Reply #11 on: May 04, 2015, 01:21:27 PM »
I bought some a few years ago.  They are hard rubber & the OEM part # is 12392-MJ0-000.  Don't have any idea about availability or price...Jim Smiley
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
