February 10, 2026, 07:46:21 AM *
Author Topic: 99 I/S rad end fairing  (Read 749 times)
Paladin528
« on: May 06, 2015, 06:19:29 PM »
I am looking for a right hand side rad fairing.  The pin that goes into the grommet is broken. I only need the piece that the pin is on not the whole fairing.  Has anyone seen one for a decent price or just have one they no longer need?
« Reply #1 on: May 06, 2015, 06:31:53 PM »
Not sure what you are calling a pin but try Pinwall cycle on eBay.
« Reply #2 on: May 07, 2015, 11:03:20 AM »
I think you'll get more response if you refer to that piece as a "pod".
Steve K (IA)
Cedar Rapids, Iowa
« Reply #3 on: May 07, 2015, 02:09:43 PM »
There could be a way to fix it...
A while back someone posted about a process where you could make a mold of a part and recreate it with a liquid plastic.  In your case, it would be a mold of that "pin" from the other pod.  Then you could JB Weld it to where it is missing.
(I know I saved the link for this product/process, but can't find it)
Update.  Found it.  They are showing how to recreate a broken tab.  This should work for your situation.
http://www.urethanesupply.com/Fairing-Tab-Repair/
Video   https://www.youtube.com/watch?v=P9DrfxHy2GU
Do you have the broken off piece?
Is the pod stable enough with just the 2 bolts holding it?
Otherwise that part is $204.  You probably know that already.
« Last Edit: May 07, 2015, 04:57:59 PM by Steve K (IA) » Logged
States I Have Ridden In
Steve K (IA)
Cedar Rapids, Iowa
« Reply #4 on: May 07, 2015, 02:14:22 PM »
When the I/S came out, Honda referred to the "pods" as the lower fairing.
