January 29, 2026, 01:56:55 PM
I/S shocks
Topic: I/S shocks (Read 1882 times)
I/S shocks
August 28, 2009, 03:57:11 PM »
If I install these shocks on my tourer, what can I expect? smoother ride? harsher ride? better handling etc.?
Thanks for all of your responses.
John U.
Southern Delaware
Re: I/S shocks
August 28, 2009, 06:17:51 PM »
If your tourer shocks are like mine you are likely to have a stiffer suspension, and better handling if your fork springs are in good shape. My IS is stiffer on it's softest setting than the Tourer is on the strongest. The softest setting won't handle two up.
Although they both have less than 20,000 miles, I think the Tourer shocks are about shot, so are the OEM fork springs. I weight 215.
KW
West Michigan
Re: I/S shocks
August 28, 2009, 07:07:29 PM »
Don't the Tourer and Interstate have the same shock?
John U.
Southern Delaware
Re: I/S shocks
August 28, 2009, 08:13:01 PM »
Nope.
Old Geezer Richard
San Antonio , Tx
Re: I/S shocks
August 28, 2009, 10:07:04 PM »
I just swapped out my old worn out OEM std shocks on my 98 std. for some I/S shocks set at the highest setting along with some new Progressive front fork springs and she handles great ..... no more wobbles or shakes into the curves ....I'm impressed .....
Last Edit: August 28, 2009, 10:08:59 PM by OLD GEEZER
If you don't care where you're going, then you ain't lost , Murphy's Law because wherever you are going to , it ain't going nowhere .... San Antonio,Tx.
