March 15, 2026, 09:40:28 PM *
Author Topic: I'm tired  (Read 1524 times)
Pappy!
Central Florida - Eustis
« on: May 09, 2015, 05:39:44 PM »
Been a busy day.
Pulled the rear tire/wheel off Lesa's yesterday and took it down and had the tire changed.
She went Dark Side on me.......she may never go back from what I hear.
Today:
-complete rear drive service on Lesa's including lubricant and pinion cup service.
-Oil and filter
-Coolant change
Mine:
Complete rear drive service including pinion cup and lubricant.
Oil and filter
Pulled the tank and rebuilt the petcock with a new kit.
Tomorrow
New fluids for Lesa's bike.
May do mine as well
Now, if you will excuse me, I have to go cook some steaks.
I tell ya', a man's work is never done!
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #1 on: May 09, 2015, 05:42:33 PM »
Pappy, take tommorow off!
sixlow
St. Augustine, Fl.
« Reply #2 on: May 09, 2015, 06:21:04 PM »
It really does wear you out all that work, you will sleep well tonight. But you had a good time didn't ya ?
Thunderbolt
Worthington Springs FL.
« Reply #3 on: May 09, 2015, 06:43:34 PM »
Good job there Pappy.  All I did was change the water pump and antifreeze on the Rocket.  First trouble it has ever had, it started a little drip from the weep hole.  Oh and I replaced two tires on my single axle trailer with two that I took off the RV including removing all four from the rim and remounting as the number of bolt holes was wrong.  I'm with you though, I'm tired too.
TJ
Lake Placid , Fl.
« Reply #4 on: May 09, 2015, 07:37:07 PM »
 cooldude Pappy...
MelbourneDan
Satellite Beach, FL
« Reply #5 on: May 12, 2015, 07:01:04 PM »
Sounds like a great day above the dirt!
Dan
Pappy!
« Reply #6 on: May 12, 2015, 07:53:03 PM »
It was a productive day....for the cursed Deer flies!!! Bet I killed over 20 of them and fed probably 5 times that many. Those darn things actually take a measurable amount of productive time away from you when you are trying to get things done.
Was like......arrgggghhhhh!.....do I continue to fit the rear drive back into the U-Joint or kill that SOB Deer fly?
