February 10, 2026, 11:22:56 AM *
Author Topic: Risers for Interstate  (Read 3497 times)
BIG--T
The Twilight Zone
« on: May 10, 2015, 04:04:15 AM »
I need some risers  for my Interstate. I don't want to have to replace hoses and cables so do you know where I can find some?  Smiley
« Reply #1 on: May 10, 2015, 05:22:39 AM »
Aeromach 4" Pullback Risers are what I have...
I got mine years ago from Big Mike... google sez these folks still have them...
http://www.hellrisercustoms.com/bikes/24/maker/AERM
BIG--T
The Twilight Zone
« Reply #2 on: May 10, 2015, 06:03:23 AM »
Thanks Mike!  cooldude
PharmBoy
Lawton, Ok
« Reply #3 on: May 10, 2015, 06:07:56 AM »
There are others, but nothing better IMHO.  I have 2 sets...Jim Smiley
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
« Reply #4 on: May 10, 2015, 07:03:14 AM »
I have the same Aeromachs and they are great.  You can buy cheaper 4", but not stronger.  And a straight bolt up with no mods or changes necessary.  Except you may want to turn your handlebar wire guides (clips) around 180*, easy to do (check wire tightness at full lock each way).
Farther
Quimper Peninsula, WA
« Reply #5 on: May 10, 2015, 10:54:04 AM »
If you want to preserve the stock look and keep prices reasonable something like this has worked for me for about the last six years: http://www.twistedthrottle.com/handlebar-risers-honda-shadow-valkyrie-magna-vtx1300-pacific-coast-pc800-with-1-inch-diameter-handlebars
~Farther
Six-Cylinder Hooligan
« Reply #6 on: May 10, 2015, 04:36:23 PM »
I got these on mine... I like 'em- http://www.ebay.com/itm/CHROME-SQUARE-1-HANDLEBAR-1-1-2-RISER-FOR-HONDA-SUZUKI-KAWASAKI-YAMAHA-CRUISER-/171780438237?hash=item27fee978dd&vxp=mtr
Nothing fancy but they do make it more comfy & price was right-IMO!
BIG--T
The Twilight Zone
« Reply #7 on: May 10, 2015, 07:51:37 PM »
Thanks guys, Ummm that got me thinking. I think I may have some 4" risers for a VTX 1800, wonder if they'll works?
« Reply #8 on: May 11, 2015, 05:34:15 AM »
I agree that these are the best choice.  cooldude I tried a competitor brand and had some trouble with the fit against the fairing. The aeromachs fit great.
« Last Edit: May 11, 2015, 12:43:00 PM by salty1 » Logged
My rides:
BIG--T
The Twilight Zone
« Reply #9 on: May 11, 2015, 05:47:39 AM »
I agree that these are the best choice.  cooldude I tried a competitor brand and had some trouble with the fit again st the fairing. The aeromachs fit great.
Thanks man, I hadn't thought about the fairing.  Undecided
0leman
Klamath Falls, Or
« Reply #10 on: May 11, 2015, 08:11:44 AM »
Since I got my I/S 8 years ago and didn't get all the info on what he did to the bike.  What is the size of OEM risers?   And how are the measured.  Just want to know if I have OEM or aftermarket.
BIG--T
The Twilight Zone
« Reply #11 on: May 11, 2015, 08:50:38 AM »
I'm not sure on the OEM but do know they are shorter than 4" which a lot of people go to
« Reply #12 on: May 11, 2015, 10:41:08 AM »
This link is helpful (and old).
Tim Skelton measured the stock OE valk risers at 3 1/8".  I gave mine to someone 10 years ago.
http://timskelton.com/valkyrie/how_to/risers.htm
Stock risers on the left.
The LaMonster risers discussed in this link are essentially identical to the Aeromach 4" honda pullbacks.  They were sold by HDL for a long time, but since sold, I don't see them there anymore.  Same with the 4 1/4" Cycle House (in-house HDL) risers, no longer sold (that I can find).
Now Skelton said the Lamonster (Aeromach) .... provide an additional 1.25" pullback and .25" rise. but I think that is in error.  Seems to me if they are 4" risers, they would be 3/4-7/8" taller than 3 1/8" stock risers(but mounted on an angled triple tree, actual rise may not be the same as simply measuring the difference in length of each riser).  1.25" additional pullback may be accurate, but this still sounds a bit short to me.  When HDL did sell these, the advertised rise and pullback was NOT consistent with what Skelton reported.
Now the Aeromach 4" Honda pullbacks are specifically advertised for 1300 VTX (but also as fitting all valks) and they say.... The risers .... raising the bars up 2"  and 1-1/2" closer to you from the stock location , while allowing you to retain your stock throttle and brake cables.
This sounds closer to accurate for pullback, but how do 4" risers give you two inches taller than 3 1/8" valk stock risers?  (They may be speaking only about the 1300 VTX risers, of which I am ignorant.)
http://www.aeromachmfg.com/RISER_SET_4_VTX_Retro_1300_p/am-4120c.htm
Suffice it to say, I have never heard anyone not like these risers, except for those who chose the Harley deuce knockoffs at 5.5" rise (which require drilling the triple tree out a few thousandths/or metric/SAE conversion riser bolts, rerouting throttle cables inside the tree, and grinding/cutting off the dome on the bottom of the risers)  These are also shown in the Skelton link, but his mention of longer bolts is not exactly correct.
I have the Aeromach on one interstate, and the Harley deuce on the other (supervalk).  Both are great (stock is not great).  I like the deuce more for kicked back cruising on the hwy pegs and freeways, and I like the Aeromach better for performance riding in the mountains, sitting up and paying attention.
« Last Edit: May 11, 2015, 10:52:19 AM by Jess from VA » Logged
PAVALKER
Pittsburgh, Pa
« Reply #13 on: May 11, 2015, 04:00:04 PM »
Two on eBay relatively inexpensive.....and neither require mods.
http://www.ebay.com/itm/141091566666?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
And......a variable rise riser, which I currently have on....
http://www.ebay.com/itm/121621210271?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
John
BIG--T
The Twilight Zone
« Reply #14 on: May 12, 2015, 05:51:41 AM »
Thanks Jess for all the info! The Aeromachs  are pricey but nice and I know I don't want the Deuce because of the hassle.  Smiley
BIG--T
The Twilight Zone
« Reply #15 on: May 12, 2015, 05:57:48 AM »
Thanks John, the first link doesn't mention the Interstate but can't imagine why they wouldn't work...unless they hit the fairing. On the second link, what is the height? They was one brand that i can't remember on a forum that broke!! That would be some kind of scary!! Shocked
BIG--T
The Twilight Zone
« Reply #16 on: May 12, 2015, 05:58:42 AM »
Thanks everyone for all your help!  Wink
specialdose
Jonesboro, Ga
« Reply #17 on: May 12, 2015, 07:58:49 AM »
     I went the same route as Farther. Works for me. Cheap, nice looking, easy install. I bought mine on ebay per a discussion about risers
2 yrs ago. Foot note, I am 6' 4". 35" sleeve length, long arms. Tilted the bars back just a bump from stock position. Put me in the sweet spot.
BIG--T
The Twilight Zone
« Reply #18 on: May 12, 2015, 12:17:33 PM »
Thanks, we are close to the same size and glad to know that extra inch  helped.  Smiley
PAVALKER
Pittsburgh, Pa
« Reply #19 on: May 12, 2015, 06:58:27 PM »
They don't hit the fairing at all.  I have them on the lower setting, and if you add any or all the other spacers, it just brings the bars back further not up much more where it would contact the fairing.  I'd say they are  at 4.5.
I do recall a photo of a broken set..but not sure if they are the ones or similar.
« Last Edit: May 12, 2015, 07:03:30 PM by PAVALKER » Logged
John
Bigwolf
Cookeville, TN
« Reply #20 on: May 13, 2015, 12:07:53 AM »
Another riser you may want to look at is PhatRisers by Scoot Works.  Chrome priced about the same as Aeromachs.  Polished Aluminum are a little cheaper.
http://www.scootworks.com/shop.cgi/page=partshonhandle.htm/SID=PUT_SID_HERE
They have some chrome blems for a reduced price: http://www.scootworks.com/shop.cgi/page=partsspecials.htm/SID=1431499564.5805
Bigwolf
« Reply #21 on: May 13, 2015, 05:20:04 AM »
I didn't want to mention names in my earlier post, but it was a set of 4 inch Phat risers that I had a problem with on my IS. They were too tall and didn't clear the fairing. Luckily I had a set of Aeromachs on my Standard that I placed on the IS and then put the Phats on the  Standard.
My rides:
BobB
« Reply #22 on: May 13, 2015, 06:43:37 AM »
The PO of my '98 Tourer told me that the risers he put on were for a H-D Sportser.  They have 4.5" rise,  1.5" pull back and are well made...
Bigwolf
Cookeville, TN
« Reply #23 on: May 13, 2015, 09:55:10 AM »
salty1, That is good information to know.  I like the PhatRisers on my standard.
vicnelson
'99 Tourer in Smoky Mt.
Prescott, AZ
« Reply #24 on: May 13, 2015, 09:59:24 AM »
I don't have the IS but the Tourer. I did not want to change any cables but wanted an extra inch of extention. for $75 I ordered a one inch extension that is the easiest fix ever. It goes on top of the riser and extends it one inch and provides new bolts. I got it at WWW.GENMARMFG.COM
Check it out it is an easy fix. I found that one inch is all I had for slack.
