February 10, 2026, 11:22:22 AM *
Author Topic: 4411 4.5 inch led lights  (Read 841 times)
N8171S
Marlboro, Mass
« on: May 10, 2015, 10:01:03 AM »
Does anyone know if the 4.5 inch led tractor bulbs being sold on ebay will fit in the cobra lights?
BobB
« Reply #1 on: May 10, 2015, 02:49:51 PM »
I'm not sure exactly which 4411 insert your are looking at, an item number would certainly help.  I see only lamps intended for off-road use, so I would question the light patern they put out.  Some of them also appear to require deeper housings.  These lamps put out a great deal of heat in the rear end.
I've replaced the 4-1/2" sealed beam lamps on my Valk with 3-1/2" lamps that use halogin bulbs...
« Reply #2 on: May 10, 2015, 05:46:12 PM »
They work with some modification.
http://www.valkyrieforum.com/bbs/index.php?topic=76391.0
N8171S
Marlboro, Mass
« Reply #3 on: May 13, 2015, 01:54:53 PM »
Thanks,  I thought I saw your post awhile back but just wanted to check.  Ordered a  set of the bulbs.
Mr.BubblesVRCCDS0008
« Reply #4 on: May 14, 2015, 05:22:48 PM »
Do you think these might replace the stock fog lights on an interstate with factory fog lights.
