February 10, 2026, 11:22:20 AM
Factory Foglights ?
Topic: Factory Foglights ? (Read 804 times)
Mr.BubblesVRCCDS0008
Factory Foglights ?
May 14, 2015, 04:06:15 PM »
Are factory foglights adjustable and are there any LED bulbs replacements. It looks like they maybe a seal beam type bulb.
Re: Factory Foglights ?
May 14, 2015, 04:12:54 PM »
Are you needing the I/S pod lights? If so, I think they're made of unobtanium now. If you find a set used, hang onto your wallet.
May 14, 2015, 04:34:57 PM »
Just bought an interstate with them on it. just want to aim them better or replace bulbs with LEDs.
Flrider
Jack
Kissimmee FL
May 14, 2015, 07:37:27 PM »
You have to take the pods off and there will be an adjustment screw that you can turn.
You can also change the bulbs through the back of the light, have not done it in awhile, I think you have to take the back plate off and you will be able to access the light bulb.
From what I understand, you should run a 35 watt because the 55 watt might cause the lens to fog up.
As far as LED's, don't know but I would be interested if doable, try doing a search.
May 14, 2015, 09:23:23 PM »
If LEDs are available: try here.
www.1000bulbs.com
I had good luck finding some halogens but had to call and ask for help. They sell lots of bulbs.
