November 20, 2025, 12:07:46 AM *
Author Topic: Darkside question  (Read 1744 times)
Old Geezer Richard
San Antonio , Tx
« on: August 28, 2009, 09:44:36 PM »
Will I have to replace those O rings everytime I grease the spline every 12,000miles with a car tire ..... I'm coming up to 11,000 miles right now with my CT .....
DFragn
« Reply #1 on: August 29, 2009, 02:35:57 AM »
Probably not.
Inspect them and the thrust washer though.
Grandpot
Fort Mill, South Carolina
« Reply #2 on: August 29, 2009, 03:49:18 AM »
Whether you have a CT or a MC tire, it makes no difference.  You need to lubricate the splines and inspect the O rings on a regular basis.  The book says to replace the O-rings every time the wheel is removed.  From the past posts I’ve read, no one seems to do it that often, but you certainly need to inspect them. cooldude
« Reply #3 on: August 29, 2009, 05:35:03 AM »
I replace mine. There cheap enough, esp from Carolina bike/trike. I inspect my thrust. I do mine every spring regaurdless of mileage. Usually no more then 15,000 miles. This is my 1st season on a CT but not nearly the miles I should have so far.  Undecided
stude31
Topeka,ks
« Reply #4 on: August 29, 2009, 07:43:56 PM »
I'm with you Fudgie... I buy my o-rings from carolina bike... It is much less to replace o-rings than to replace splines..  The alternative doesn't sound very appealing to me...   To each his own... I also run a C/T and I inspect relube and new o-rings every 15k miles.  All of my o-rings that I have taken off in that time frame have looked good but I just replace them...
roboto65
Conroe,TX
« Reply #5 on: August 29, 2009, 07:55:08 PM »
Just got done doing mine with Wizards help had them but they were fine plenty of lube and the thrust wassher looked good bearing finr so I put it back together and called it a day. Well that and put a Tourer rotor on a Interstate !!
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
