February 10, 2026, 09:37:46 AM
new noise when I hit the start button
Topic: new noise when I hit the start button (Read 775 times)
Tfrank59
'98 Tourer
Western Washington
May 18, 2015, 04:08:32 PM »
I'm thinking this is the starter relay...it makes a pop when I hit the start button, just began today, and it's an electrical thing--would it be the button itself or the relay, which I understand is down near the battery? Almost sounds like it's coming from the button but I may be wrong. I'm at work right now so can't get her apart--starts up okay--but once home and have a chance want to know what to look for. thanks.
-Tom
Keep the rubber side down. USMC '78-'84
Re: new noise when I hit the start button
May 18, 2015, 06:10:43 PM »
The starter relay is under the RH side cover. Mine would pop for no reason sometimes, maybe 3 times while I had my bike. I don't feel it is a sign of anything, but I would inspect it.
Remove the cover, inspect the leads for corrosion or heat damage. Maybe even remove the leads and sand them to get fresh metal again. Remove and replace he fuse.
Maybe someone else will have more experience or suggestions on what to do.
May 19, 2015, 09:48:27 AM »
This is what you have I bet........
http://www.valkyrieforum.com/bbs/index.php/topic,74229.0.html
Tfrank59
'98 Tourer
Western Washington
May 19, 2015, 10:14:43 AM »
Quote from: Chrisj CMA on May 19, 2015, 09:48:27 AM
Well I have a spare starter relay, so I'll probably just change it out. Funny because after the heat of the day past and the bike cooled down it doesn't do it now.
-Tom
