February 10, 2026, 11:25:35 AM
Dry ice to shrink bearing races?
Topic: Dry ice to shrink bearing races? (Read 1714 times)
gregk
Retired
Chippewa Falls, wi.
May 21, 2015, 05:17:51 PM »
Anybody try this? Did neck bearings once by putting the races in the freezer and it was still bear to install the races. Maybe using a little dry ice would benefit. Anybody got any view points on this.
xman
Lincoln Park NJ, Valk Home Lackawaxen PA
Re: Dry ice to shrink bearing races?
May 21, 2015, 06:53:16 PM »
Yes, with interference fit you need to expand one side, and shrink the other side. Normally heating one side to 250F is all you need to do. But dry ice shafts or bearings as well helps.
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
May 21, 2015, 07:51:38 PM »
We used dry ice and oil in the freezer for the hinge pins of our H-53 too
Dusty
Mill Bay B.C.
May 21, 2015, 10:21:08 PM »
Give the bearing races 10 minutes in the dry ice to allow the temperature to go through the steel. We were shrinking some 3 inch diameter bolts at work and they took a good half hour to shrink enough to fit in their holes.
Dusty
DK
Little Rock
May 22, 2015, 10:44:27 AM »
Dry ice & alcohol. Colder.
Dan
John Lane
Marysville Wa.
Marysville, Wa.
May 23, 2015, 01:10:55 PM »
Quote from: DK on May 22, 2015, 10:44:27 AM
Dan
+1 Poor mans liquid nitrogen-rubbing alcohol and dry ice!
John and Gina Lane
1998 Black Tourer
2013 F6B (Gina's)
