November 26, 2025, 08:22:26 AM *
Author Topic: Where did all that come from  (Read 1006 times)
knockdolian
« on: May 24, 2015, 11:04:23 AM »
I all, doing some bits on the IS today. I took the air box off and one of the hoses came away from a T piece on the RHS. It dumped what looked like about a cup of water. Im guessing it a hose to a breather but should the water build up that much or should itt drain off ?
Cheers
« Reply #1 on: May 24, 2015, 12:08:02 PM »
Know as Dragon Drool.
The bottom of the line with fluid in it has a plug. This should be part of your regular maintenance (frequency based upon location and use). Remove the plug and catch the fluid, inspect.
Moister from your air cleaner box.
knockdolian
« Reply #2 on: May 24, 2015, 12:11:13 PM »
Thanks for the info. Nothing to worry about then.  cooldude
« Reply #3 on: May 24, 2015, 03:07:09 PM »
Nothing to worry about, just remember to drain it every few months  cooldude
idaida98
« Reply #4 on: May 24, 2015, 05:49:59 PM »
I never worry about mine because I have had it unplugged since I bought the valkyrie in 2002 : Roll Eyes
Pete
« Reply #5 on: May 24, 2015, 05:57:57 PM »
That could allow dust and dirt to be sucked up and into the air box. Personally I would plug it but it is your bike and your choice.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #6 on: May 25, 2015, 07:45:37 AM »
you need the  plug in there with out it you have a major vacuum leak
« Reply #7 on: May 25, 2015, 08:11:05 AM »
Yeah but that way he don't have to kneel down to empty it two or three times a year uglystupid2 2funny 2funny 2funny
Farther
Quimper Peninsula, WA
« Reply #8 on: May 25, 2015, 07:43:41 PM »
I emptied mine for the second time in eight years.  Got about a tablespoon each time.
~Farther
idaida98
« Reply #9 on: May 26, 2015, 06:03:36 PM »
Doesn't seem to affect it, average 37 mpg and it runs fine.I will result it per your suggestion and see if I notice any change.
