November 26, 2025, 08:23:36 AM *
Author Topic: chrome around fuel shutoff.  (Read 1172 times)
jprides
« on: May 27, 2015, 05:34:16 PM »
2003 Valk standard. After removing the  tank and the chrome fuel shutoff and trim piece around it I am having trouble getting it back on. There is the chrome piece with the hole in it that goes around the shutoff and three bolts and three spacers. I cant seem to get the right configuration.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #1 on: May 27, 2015, 05:46:37 PM »
Does this help?
http://www.partzilla.com/parts/search/Honda/Motorcycle/2000/GL1500CF+A/FUEL+TANK/parts.html
States I Have Ridden In
Dak44312
Akron, OH
« Reply #2 on: May 27, 2015, 06:21:31 PM »
I think he is talking about the chrome engine hanger covers, which are a Hondaline accessory.  It's been a while, but I THINK no spacers are used in the petcock bracket hole, 2 spacers on the frontmost hole ( 1 on each side of the coil bracket) and 1 on the bottom hole, between the coil bracket and engine hanger. Hope that makes sense. I'm going from memory.
« Reply #3 on: May 27, 2015, 06:45:38 PM »
They are a pain the butt. That's why I don't remove mine anymore. cooldude I think they are more difficult if you have tank spaced also.
« Last Edit: May 27, 2015, 06:47:09 PM by meathead » Logged
Steve K (IA)
Cedar Rapids, Iowa
« Reply #4 on: May 27, 2015, 11:33:21 PM »
Yea, after I posted that I was thinking might of been talking about the chrome hangers.  I done the stud mod to mine years ago.  I don't worry about those spacers anymore.
I remember the first time, dropping spacers and thinking I'd never find them again.
Joe Hummer
Arnold, MO
« Reply #5 on: May 28, 2015, 04:52:51 AM »
I took longer bolts and made some studs out of them.  A nut behind the hanger cover stays in place when I remove the cover...a nut in front of the cover holds the cover in place.  Makes removing it MUCH easier.
As for configuration, there are 3 bolts that go into the engine hanger.  The top left one and the bottom one gets a spacer.  The top right one holds the petcock handle (which has a spacer inside it).
Hope this helps.
Joe
1999 Valkyrie Interstate
RainMaker
Arlington, TX
« Reply #6 on: May 28, 2015, 06:53:56 AM »
Would love to see a writeup, pictures of that "stud mod".  It is a major PIA to remove the tank due to the "rube goldberg" assortment of spacers.
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Joe Hummer
Arnold, MO
« Reply #7 on: May 28, 2015, 08:42:00 AM »
I will see if I can get some pictures of the process this weekend and add it to this post.  Pretty easy to do and great for removing them you have to.
Joe
72cutlassdude
99 Super Valk VRCC 35563
Laingsburg, MI.
« Reply #8 on: May 28, 2015, 08:44:02 AM »
I JB Welded the spacers to the back side of the hanger, works like a charm!
"Common sense is not a flower that grows in everyone's garden"
quexpress
Montreal, Québec, Canada
« Reply #9 on: May 28, 2015, 06:16:57 PM »
BigBF has a pictorial at http://www.bigbf.com/bigbf_shop/engine_hang_covers/index.htm
and hardware/fasteners/studs for sale at http://www.bigbf.com/bigbf_shop/sale/engine_hanger/index.htm
Good luck!  cooldude
I still have a full deck.
I just shuffle slower ...
Joe Hummer
Arnold, MO
« Reply #10 on: May 28, 2015, 06:19:22 PM »
Good luck!  cooldude
Hey...That works too.  Thanks for the information quexpress!!
