September 05, 2025, 04:00:33 AM *
Author Topic: vacumn lines  (Read 1230 times)
RONNIEB
NEWCASTLE, OKLAHOMA
« on: May 29, 2015, 06:26:06 PM »
Ifthe 2 vacumn lines to the center cylinders have holes, what problems will result from leaving lines off and capping the ports? would this not be like a "desmog" shortcut?
1999black standard; 2000 black tourer; 1999 red/black interstate
« Reply #1 on: May 29, 2015, 06:51:30 PM »
No.  Replace the vacuum lines unless you remove all the smog crap
RONNIEB
NEWCASTLE, OKLAHOMA
« Reply #2 on: May 30, 2015, 11:07:38 PM »
Will I do harm running till get lines replaced?
« Reply #3 on: May 31, 2015, 05:41:18 AM »
It won't run the way it should.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #4 on: May 31, 2015, 01:22:26 PM »
Ronnie where in Oklahoma are you
RONNIEB
NEWCASTLE, OKLAHOMA
« Reply #5 on: May 31, 2015, 10:21:28 PM »
In OKC. Bike runs like a raped ape after synced.carbs and plugged of the 2 ports to the leaking vacuum lines. Just did.not know if this will allow exhaust gases to leak back from the tubes thAt go to the smog valves
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #6 on: June 01, 2015, 04:03:20 AM »
if you ever get to Tulsa stop in and I will take a look at it for you
« Reply #7 on: June 01, 2015, 07:26:39 AM »
I would say its better to stop the vacuum leaks just long enough until you find the time to replace the lines or perform a proper complete desmog.
I think many a Valk has been run for awhile with vacuum line leaks with no apparent problems/damage, but, vacuum leaks aren't a good thing and should be corrected as soon as possible. These monsters don't run well with those lines leaking. No engine runs well or should be run for long with vacuum leaks.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #8 on: June 01, 2015, 07:31:41 AM »
Well said Patrick
Gryphon
Resistance is futile; if less than 1 ohm.
Fulton, MO
« Reply #9 on: June 01, 2015, 08:39:58 AM »
At the very least, run by O'Reilly's and grab a pack of caps.  They are only $4 and will keep you from sucking stuff into the intakes.  It will get you by until you can get proper ones with clamps.  Personally, my 2 center lines run through check valves to a T and then to my cruise control.  Never leave a port open to the outside if you can avoid it.
RONNIEB
NEWCASTLE, OKLAHOMA
« Reply #10 on: June 01, 2015, 01:29:16 PM »
Ports are.capped, no vacuum leaks. Been mechanic a long time. Foreman at Kw truck now. Just didn't know what the other side of pair valve / exhaust would behave like
RONNIEB
NEWCASTLE, OKLAHOMA
« Reply #11 on: June 01, 2015, 09:53:12 PM »
