September 05, 2025, 03:53:36 AM *
Author Topic: How to align 3 drilled holes in exhaust pipe  (Read 933 times)
blackvalk
PARK CITY, UTAH
« on: May 30, 2015, 07:13:53 PM »
I purchased the rear exhaust pipe extensions because my pipes were too short so they were burning my hard bags. I need to drill the 3 holes that attach the pipes to the front existing pipe.
Can someone till me the best way to drill the 3 holes in the right place so the screws will align with the existing holes?
Bill
97valk
Franklinville, NC
« Reply #1 on: May 30, 2015, 07:25:32 PM »
Wrap a piece of paper around your short pipe extensions and use a pencil to punch through the existing holes. Transfer that paper to your new extensions and mark the holes with a marker. Careful punching and marking as close as you can. Drill and debar holes.
Riding with the wind in my face, the past at my back and the road beneath my wheels............ Paradise
« Reply #2 on: May 30, 2015, 07:28:23 PM »
Paper template? I'd say CAREFUL measurements but I KNOW how that would work fer me. Good luck with your project. RIDE SAFE.
« Reply #3 on: May 30, 2015, 07:29:32 PM »
I used the exact same method, but instead of paper, I used blue painters tape to transfer the marks/holes.
Measure twice, drill once.   Wink
blackvalk
PARK CITY, UTAH
« Reply #4 on: May 31, 2015, 03:16:17 AM »
Thanks guys!
All good ideas,
Bill
DK
Little Rock
« Reply #5 on: May 31, 2015, 03:42:36 AM »
Remember that there is both a right hand and a left hand configuration.
Don't ask how I learned this.
Dan
« Reply #6 on: May 31, 2015, 03:45:04 AM »
Once marked, use a punch to slightly dimple the marks, otherwise your drill bit will walk and mar the chrome.  Then first drill with a sharp 1/8 inch bit before the larger bit.  Also, assuming this is just tips, you probably only need one hole/screw.  They are a tight slip fit, and I covered the ends with soft pine and rapped them on with a rubber mallet, one screw will hold them, and make that one on the inside.
« Reply #7 on: May 31, 2015, 11:31:40 AM »
What Jess said......but I drilled two holes.
Devil Dog
Photo Won't Load
Ohio
« Reply #8 on: June 01, 2015, 09:41:01 PM »
Blue painters tape.  Template will be mirror image.
LIFE IS FULL OF CURVES, LEAN IN AND ENJOY THE RIDE...
69-CB175, 74-CB450F, 76-CB750k, 78-CB750F, 82-V45, 74-CB750k hardtail springer, 93-VLX,        96-VT1100, Current 01-Valkryie & 81-GL1100 Standard
