February 10, 2026, 01:12:47 PM *
Author Topic: OEM Saddlebag Rubber Seal  (Read 1307 times)
indybobm
Franklin, Indiana VRCC # 5258
« on: May 31, 2015, 06:07:04 AM »
This is not a big problem but it is aggravating. When I lift the saddlebag lid, most of the time the rubber seal will pop out of the channel in the saddlebag. Then I have to fiddle with it to get it back in. What do people use to glue the rubber seal in the channel? Silicon just makes a gooey mess.
When I had my first Valk years ago I was told to put talcum powder on the seal to keep it from sticking to the lid. Seems like the seal would stick to the lid and when you opened the lid it would pull the seal out of the channel.
So many roads, so little time
VRCC # 5258
« Reply #1 on: May 31, 2015, 06:30:55 AM »
I pulled my seals off and ran a bead of silicone on the top edge then stuck the seals back on. Problem solved
« Reply #2 on: May 31, 2015, 06:47:23 AM »
That worked for me also.
« Reply #3 on: May 31, 2015, 07:05:52 AM »
There are suppose to be seals?  Grin
WintrSol
Florissant, MO
« Reply #4 on: May 31, 2015, 07:12:05 AM »
Before the seals stick to the wrong side of anything, I use GM's recommended treatment for rubber seals: silicone grease. It keeps the rubber 'live' longer, protects it from the elements, and keeps it from sticking where it shouldn't. Car door, window, trunk, hood, and any other seal of that kind.
BonS
Blue Springs, MO
« Reply #5 on: May 31, 2015, 07:28:25 AM »
I couldn't agree more, I use a 50 weight silicone oil for rubbing on seals. It's made for paint ball gun lubrication and lasts a long, long time. The thickness of the 50 weight lets me put it on my finger to spread it around without it dripping off. I use a water-thin silicone oil for easing assembly of tight fitting parts. FWIW my favorite quick drying flexible glue that works on rubber and plastic is Loctite vinyl, fabric & plastic flexible adhesive. It works well, is transparent and permanent, and yet and is easily removed when desired.
indybobm
« Reply #6 on: May 31, 2015, 07:49:05 AM »
Thanks for the replies. I tried gluing the seals down using silicone but it turned into a mess.  I'll try the silicone grease on the top of the seals and keep the underside of the lids waxed. The seal is a double channel seal and sometimes is hard to get back in.
VRCC # 5258
Icelander
Snohomish, WA
« Reply #7 on: May 31, 2015, 08:49:18 AM »
Had the same problem with my right-side bag. I went to O'Reilly's and bought some 3M weatherstripping adhesive. It's stringy and will get everywhere but it holds the seal down well and even repaired a torn weatherstripping on the tailgate of my Tahoe. A little goes a long way.
It's in a rather generic red box and I couldn't find it on the shelves but the sales guy knew where it was.
Hope this helps!
Icelander
1998 Valkyrie Tourer.
VRCC Member #36337
signart
Crossville, Tennessee
« Reply #8 on: May 31, 2015, 10:07:12 AM »
Permatex also makes a weather strip adhesive, in black, which is what I used on my bag seals. I just happened to have some. 3M is very good and very aggressive. Use either very sparingly.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #9 on: May 31, 2015, 01:25:58 PM »
I use 3M weather strip adhesive black in color and it will hold the seal in place just fine
indybobm
« Reply #10 on: May 31, 2015, 01:36:51 PM »
Thanks again, I will try the 3M.
VRCC # 5258
