September 05, 2025, 03:59:17 AM *
Author Topic: Driveshaft Seal  (Read 840 times)
Pluggy
Vass, NC
« on: May 31, 2015, 05:35:28 PM »
That seal on the driveshaft at the pinion cup seems a bit tricky to change.  I do that because the Honda and Clymer books say it is required.  This part should not wear at all.  Do you guys change it regularly?  Any tips on making it an easy  one man job?
SteveBC777
2000 tourer red/black {minus screen}
Pattaya Thailand
« Reply #1 on: May 31, 2015, 05:58:22 PM »
The best tip for making it an easy job is to leave it well alone !!!!!
If it's not split / broken at all, then just lube it along with everything else and  re-fit.
Easy as easy gets mate..............
Spannerman to some of the nicest chaps you could ever wished to of met .
« Reply #2 on: May 31, 2015, 07:04:13 PM »
Only if it got boogered up.
0leman
Klamath Falls, Or
« Reply #3 on: June 01, 2015, 08:15:30 AM »
Leave it alone as said above.  BUT to change it, you need to remove the spring at the U-Joint end.  That is the fun part.   I used a bench vice, pair of vice grip pliers, and a clip remove plier to get spring off.
« Reply #4 on: June 01, 2015, 08:52:07 AM »
150K and still have the original seal and drive shaft. Do not change it.
« Reply #5 on: June 01, 2015, 09:47:06 AM »
Unless, of course, its messed up.  Very easy to change...one little clip at the forward end and everything slides off.  Just look closely which way the seal goes
« Reply #6 on: June 01, 2015, 10:37:58 AM »
As said, that seal doesn't do much especially if its only separating the dirt and the grease. It may have some more importance if its sealing oil like seems to be the case in some instances.
I don't find a problem with changing them, its easy. I only changed mine because I decided to add oil to the splines. If I were only greasing the splines as usual I would have left the seal alone.
