September 05, 2025, 03:52:04 AM *
Author Topic: Non valkyrie related (but shows how important is maintenance).  (Read 711 times)
Savago
Brentwood - CA
« on: June 01, 2015, 02:21:13 PM »
Dear friends
I noticed that my vstrom 2008 brakes were not performing as good as the valkyrie I/S (a motorcycle that weights more than twice and it is 16 years old).
I decided to change the brake oil (even though it looked fine through the reservoir crystal and was on the top level). Check this out:
Makes me wonder if that was the original oil when the bike was made in Japan way back in 2008?
And now the new oil:
Lesson learned: don't trust only on the reservoir crystal window. :-)
Best regards
Savago
ps: I tried to use a mityvac but the drained oil reservoir was leaking on it (came broken out of box) and ended using the goodie and oldie push brake lever/bleed method instead.
WintrSol
Florissant, MO
« Reply #1 on: June 01, 2015, 02:38:09 PM »
Brake fluid should be changed every two years, no matter how many miles are ridden. And, BTW, it is not oil but a liquid more closely related to anti-freeze, which is why it goes bad so quickly.
