February 10, 2026, 11:22:28 AM *
Author Topic: Battery died, then revived  (Read 1389 times)
« on: June 04, 2015, 01:35:30 PM »
I was out around town, stopped for gas, got ready to go and she turned over
v e r y    s l o w l y   then nothing.  So I push start it to get home (7 or 8 mi). Once at home, turn it off and she's holding 13 V off and 14 running and starting just like normal
New battery on the charger, just thought it was strange.  Battery was 3 or so years old so I already had a new one ready to charge up
« Last Edit: June 04, 2015, 07:21:17 PM by Chrisj CMA » Logged
Firefighter
Harlingen, Texas
« Reply #1 on: June 04, 2015, 01:42:19 PM »
Batterys seem strange now a days. Had a couple incidents with cars that the battery will load test good then bad then good again. Causes car problems that I never experienced in the old days. Think maybe your battery could be shorting inside or a post come loose or broken. Replacing is the first step.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
« Reply #2 on: June 04, 2015, 03:05:19 PM »
Chris, l hope it is just the battery.  I had a starter on an old GMC that lost cranking power when hot.  How would an owner know if it is starter or battery without a voltmeter on the bike at the time it failed?
Well, good thing I had a volt meter..didn't look real close but it was way low when it wouldn't start.
« Last Edit: June 04, 2015, 07:18:52 PM by Chrisj CMA » Logged
Rio Wil
« Reply #3 on: June 04, 2015, 03:07:27 PM »
Don't think I have ever heard of a bad starter on this board.....lots of bad battery' :crazy2:s....
« Reply #4 on: June 04, 2015, 04:26:58 PM »
OK, new battery all charged up and installed.  Raining, so no test ride...reading 13 V so I couldn't stand it, had to hit the starter just to see if it was going to turn over.  Guess what, a tiny tap and she was running.   I mean INSTANT...OK, so just a hint of exhaust in the family room.  I think it smells good. Let's see if Judy notices... He he he
« Reply #5 on: June 05, 2015, 08:20:41 AM »
Went out for a real good test ride, seems to run better than it has been, even though its been running fine.  A little more pep in the throttle response I guess having all the amps is more better for the ignition than having just enough to keep her running.
Paladin528
« Reply #6 on: June 05, 2015, 09:16:09 AM »
My old battery on my Shadow did that before it fully gave up the ghost.  Would be fine in the morning but after riding for a few hours it wouldnt start the bike.  if I let it sit for a while it would be fine.  Very strange behaviour.  It finally just completely died
Tfrank59
'98 Tourer
Western Washington
« Reply #7 on: June 05, 2015, 09:56:39 PM »
So was the battery actually low in the first instance or was it just a bad connection?  Oh okay I guess I read that you put a voltmeter on and the batt was low ha?  In any case I'd like to hear about how you push started her-- did you happen to be at the top of a big hill? Cheesy
« Last Edit: June 05, 2015, 09:59:42 PM by Tfrank59 » Logged
-Tom
« Reply #8 on: June 06, 2015, 05:33:51 AM »
Ok lets see I didn't "put" a Volt meter on it.  Theres one always there
Normally I just look to see that the volts are at 13 when I turn the key on.  When hitting the starter the volts drop until it starts and then climbs to 14.  Well that time it dropped as I hit the starter then just kept dropping.  I was only in the starter for 3 or 4 seconds, not near enough to drain a battery that had any life in it.
This is Florida man, we have very few big hills.  I just used the slight down hill ramping slope of the gas station driveway into the street.  I didn't even get off the bike just popped it into second, waited for no cars, feet walked it to that little ramp part of the driveway and popped the clutch.  Started right up and started the next 4 or 5 times I tried it just like normal.
I just didn't trust that battery and I had a new one so it went in
Bike is happy, Im happy.  Oh, there was a very small amount of white corrosion on the POS terminal but the connection was clean and tight
Hope that answers your questions there Tfrank
« Reply #9 on: June 06, 2015, 06:15:45 AM »
All my previous Yuasas lasted 9-10 years on a tender.  My most recent one, about 2.5yo, just lost its charge (enough to spin but not ignite, even on button let-off) from leaving the satellite radio on for about 20-25 minutes (no music, just the radio which does not turn off with the key).  It doesn't seem that that should be much of a draw.  (I suppose I could have some corrosion going on in the radio's fairing power port.)  Very small decline in parking lot allowed me a push start from the riders seat.
It worried me for the trip to NC, but no problems.  Ordering another anyway to put on the shelf.
All starts on a new battery take one tenth of a second on the button.
Tfrank59
'98 Tourer
Western Washington
« Reply #10 on: June 06, 2015, 07:53:23 AM »
Sure that answers my questions. Grin. I know Florida is kind of flat, and I appreciate your explanation of the procedure to pop start the girl, because here in Washington state we have plenty of hills but unfortunately sometimes we end up at the bottom of one. crazy2  I like that little dashboard you built with the voltmeter in there--looks like something I should add.
-Tom
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #11 on: June 06, 2015, 11:44:03 AM »
What you didn't answer was did Judy notice ?  Evil
desertrefugee
Chandler, AZ, USA
« Reply #12 on: June 07, 2015, 09:32:15 AM »
Sorry to hi-jack this thread, but I just spent some time trying to find a similar VM to the one Chris has installed.  Close, but no cigar.  Chris, would you mind sharing your source?  I'd love to have one of these...   Thanks!
'97 Bumble Bee,  '78 GL1000, '79 CBX, '78 CB750F, '74 CB750
desertrefugee
Chandler, AZ, USA
« Reply #13 on: June 07, 2015, 10:35:22 AM »
Actually, I modify my request (respectfully).  On first glance, I thought your gauge was a complete unit (chrome backing shell and all).   Looking at the photo on something other than a SMART PHONE, I can actually see now that it's a panel mount...I think.   I'm looking for a self-contained unit that mimics the OEM gauges...I believe I could fashion a bracket that mounts to the center windshield bolt.
Thanks anyway!
« Reply #14 on: June 07, 2015, 11:24:26 AM »
LOL...Ok, well first off....Judy did not notice the exhaust smell in the family room.  When I told her about it she just looked at me like "So whats the big deal" The bike is her baby too, she just doesn't mind anything about the bike.  Even when sometimes there is a gas smell, she says "why is there the smell of gas is anything wrong"  I would always check, and then say......they just do that sometimes"  And shes like ok, as long as its normal.
About the Volt Meter.  Its a marine guage from the Overtons boating gear catalog.  Yes, it is a panel type mount, but it is a very good piece of equipment.  The face is a little whiter than the faces of the factory gauges, but it doesn't look bad and the style fits real good
rekit
Let's Go!
77532
« Reply #15 on: June 07, 2015, 03:02:48 PM »
I don't have the link handy, but last week I saw a YT vid where this guy drained his car sized dead battery, flushed it with water and then baking soda twice, rinsed it again with water then put in some alum -(maybe 8 oz?)(from Amazon) mixed with water. Seemed to think a lot of lead particles flake off and short out the plates at the bottom. ( course if that was true why not just put the acid back in?) Charged it and it worked. Worked 3 months later and it was 10 or 20 degrees outside.....I cant wait to try it on a mower or something. Sick of batteries..........
Bought a brand new Z1 in 74 and sold it later to get a "family car" DOH!! My brother had a Kaw H1 at the time as well. Oh well, good times! Lately Mean Streak, CBX, Nighthawk 750, Connie, KZ1000, Yamaha TTR 250, KTM 250
