January 29, 2026, 03:11:38 PM
dyna beads and the darkside
Topic: dyna beads and the darkside (Read 2245 times)
blackcat
Nicholas Vore VRCC # 30301
Mounds, Arkansas
August 30, 2009, 06:08:07 PM »
i recently went to the darkside and would like to know how many ounces of dyna beads it takes for the car tire
______________________
03 Standard -Fast Black
00 Interstate - Red/Black
97 Tourstate - Yellow/Ivory
2010 Goldwing - Pearl Yellow
DFragn
Re: dyna beads and the darkside
August 30, 2009, 07:26:56 PM »
http://www.innovativebalancing.com/application.htm
Sharkey
GOT CURVES??
VRCCDS0184
August 30, 2009, 07:51:05 PM »
I am running two onces in my Michelin, and have been for over 7000 miles. No shakes or vibrations.
brillo1542
wheaton, il
August 31, 2009, 09:12:36 AM »
Please go to the dyna bead web site. I wanted to use dyna beads for my car tire, but the bead people said not to. It seems that the car tire is too wide for the sidewall height, causing the beads to spread out too much. Because a motorcycle tread is much rounder than a car tire, the beads can concentrate near the centerline of the tire, allowing them to balance the tire. They work, but I only use them on my front tire.
kipmilam
Newport News, VA
August 31, 2009, 09:23:18 AM »
Why bother? A car tire is so much better made than a m/c tire that you won't have a problem. 35 k now on the darkside without balancing a rear tire.
BonS
Blue Springs, MO
August 31, 2009, 01:07:34 PM »
The issue is lateral balance in low profile car tires. Many balance out just fine with the beads but some don't balance laterally. All tires balance out radially with beads alone. One approach is to balance wide, low profile, tires is to first balance using traditional lead weights for lateral balance and then add beads to dynamically fine tune the balance and maintain it for the life of the tire. If your goal was to get rid of wheel weights the this might not appeal to you at all. The previous information can be gleaned from the Innovative Balancing web site somewhere.
