April 29, 2026, 12:15:42 PM *
Author Topic: Clutch Noise when pulling lever...  (Read 3900 times)
cdorma
« on: June 04, 2015, 05:44:10 PM »
Hello, New Valk owner here...I have a 2014 and when you pull the clutch lever (with the engine off) you can hear a squishing sound or fluid moving.  It is not from the master cylinder and the fluid level shows normal.  The noise is from the back of the engine/clutch area. I thought I would give it some time, the bike has around 600 miles on it now and no change. I had a dealer look at it quickly and they said it was fine, I didn't purchase it from this dealer and I don't have another around to compare it to.  Anyone else aware of this? Not sure if this is normal or if it is an early sign that there may be a problem....Thanks.
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #1 on: June 04, 2015, 08:51:28 PM »
I'll check mine Saturday-but I don't remember any sound
mrtappan
« Reply #2 on: June 05, 2015, 07:54:05 AM »
Possible it has a small amount of air in the line.  If it's not losing fluid and shifts fine, I wouldn't even worry about it.
Profile deleted.
« Reply #3 on: June 05, 2015, 09:16:43 AM »
I think mine makes a funny squishing sound. My old Valkyrie is totally
silent. It bothered me for a while, but it kept on making the sound
after I changed out the clutch line and the associated bleeding.
I reckon it is what it is. When my buddies were looking the bike
over one of them said, "I like the way the clutch feels..."
dans2014
« Reply #4 on: June 05, 2015, 01:46:40 PM »
 cooldude Hydraulic clutch. No leaks, works good who cares
Dan's 2014 Valkyrie
bscrive
Ottawa, Ontario
« Reply #5 on: June 05, 2015, 05:12:19 PM »
Mine has the same sound.
I would not worry about it.  Clutch works, that's all I care.  If I have a problem, that is what warranties are for.
cdorma
« Reply #6 on: June 05, 2015, 07:07:50 PM »
Great!  Thanks for all the input!
_Sheffjs_
Sarasota FL
« Reply #7 on: June 06, 2015, 08:19:24 AM »
Could not hear any noise at all and dead silence when testing. Strange.
