March 23, 2026, 06:33:38 PM *
Author Topic: will there be a lift at Inzane?  (Read 5206 times)
O-B-1
Vancouver, WA
« on: June 07, 2015, 05:38:43 AM »
Not sure my rear tire is going to hold out. Anyone know I someone will have a lift at Inzane?
Maybe someone could help me put a car tire on?
I am here at a campground in Missoula... The Avon I wearing rapidly with my gear on board.
I-90 between Hayden Lake, ID and Missoula has empty tar snakes, nay, they are crevasses! Pot holes in the cement and huge unfilled cracks. I can't believe they wouldn't maintain a freeway better than that.
Guess I should have ordered a tire last month... But other things got in the way.
David W. Mitchell
1999 Honda Valkyrie GL1500C
Farther
Quimper Peninsula, WA
« Reply #1 on: June 07, 2015, 07:27:41 AM »
If you can make it to Rapid City, SD there is Rice Motors which is a Honda dealer that may help.
~Farther
« Reply #2 on: June 07, 2015, 10:15:25 AM »
There is a Honda dealer right across from InZane. South of I-90 at the same exit. Outdoor motorsport is the name. Im sure BigBF will have a lift to put it on. OMS maybe closed Monday but JP cycles in Sturgis should be open. Good chance of getting the right tire in Sturgis.
Gitter
Mont Belvieu, Texas
« Reply #3 on: June 07, 2015, 12:40:21 PM »
I'm bringing a Atv/motorcycle jack. If that helps
Kevin
1997 Standard "The Jet"
2000 Valkyrie IS
2001 Valkyrie IS
2000 Valkyrie IS
1986 Honda Shaddow
O-B-1
Vancouver, WA
« Reply #4 on: June 07, 2015, 05:54:11 PM »
Made it to Billings... Just doing 65mph on the speedo to keep stresses down. I will check with Redline Honda here, tomorrow morning.
Won't make dinner with ya all tonight, bummer.
David W. Mitchell
nogrey
Nampa, Idaho
« Reply #5 on: June 08, 2015, 04:34:36 AM »
Big BF is here and should have dang near anything you could need. What are you coming in/on? Did the guys at Carl's get your Valk running?
O-B-1
Vancouver, WA
« Reply #6 on: June 09, 2015, 08:53:50 PM »
The dealer sold me two Metzlers. Good to go.
So went to Big BF today, asked if he could check carb synch for me.
Previous owner said there was one cylinder just not putting out as much power as the others, thought it was #6.  Big BF found the petcock diaphragm was ruptured. Fixed me up. She runs clean, now.
Thanks Big BF!
David W. Mitchell
