November 20, 2025, 12:07:53 AM *
Author Topic: Not a Valkyrie, but a Honda CB550 Four question?  (Read 2169 times)
SlowRoad
Hartselle AL
« on: August 30, 2009, 11:16:39 PM »
  I am working on a '75 550 Four. It is only running on 2 cylinders. Runs on 2 and 4, but nothing on 1 and 3. 1 and 3 both seem to be getting gas and spark, so I am at my wits end trying to figure it out.
  Bike has new coils and points seem to be good. It is firing on one cylinder off each coil. I have tried switching wires and post on the coils with the same result. I always thought on the older models that if you get gas and fire it will run, but that is not proving to be true in this case. Carbs look good, put in new plugs, checked and double checked timing, checked compression and everything else I can think to check.  Any advice from you guys that may have worked on them in the past?
Tim
Warlock
Magnolia, Ms
« Reply #1 on: August 31, 2009, 05:08:50 AM »
Might try and check the diaphragm on the carb needles. I had several years ago some had went bad and it sounded like it was missing.
I guess these has the vacuum slides.
David
« Reply #2 on: August 31, 2009, 05:35:15 AM »
open up the idle mixture screws and check the coils. coils where known to crack and leak out the oil.
SlowRoad
Hartselle AL
« Reply #3 on: August 31, 2009, 07:14:08 AM »
David
David, I thought about that and took the top off the carb to find mechanical slides. The slides are operated directly by the throttle linkage.
Thanks.
Tim
« Last Edit: August 31, 2009, 07:16:02 AM by SlowRoad » Logged
SlowRoad
Hartselle AL
« Reply #4 on: August 31, 2009, 07:15:40 AM »
I tried opening the idle mixture screws on those two carbs with no difference. The coils are brand new and all plugs are firing when I checked them.
Thanks.
Tim
BigMac (SoCal)
Moreno Valley, California
« Reply #5 on: August 31, 2009, 07:54:10 AM »
Check the condensers. Your points could be fine but the condensers could be bad. It's a common problem on those old honda fours with points. I had about 10 of them over the years and it does happen now and them.
good Luck,
Dave
dreamaker
Harrison Township, Michigan
« Reply #6 on: August 31, 2009, 08:24:26 AM »
Just to give you a little incentive, this was my '72 Honda CB500 four I built and traded for a street rod. Built it start to finish. I'm still looking for it, hope to get it back one day.
Dan
« Reply #7 on: August 31, 2009, 10:19:49 AM »
I agree with most all that indicate it's still an electrical ignition problem.
You can manually test the coils, wires, and points and condensers. There are specs for all.
Additionally I would insure the correct wires to the correct cylinders. it doesn't make much sense to me when you say "It is firing on one cylinder off each coil."
Highly improbable problem, being identical to two individual systems.
SlowRoad
Hartselle AL
« Reply #8 on: August 31, 2009, 07:10:49 PM »
I think you just nailed it. It came in with the coils already wired. I just looked up a wiring diagram and I think the coils are going to the wrong plugs. I will try it in the next day or so and see if that doesn't get it going.
Thanks to everyone for the suggestions.  I have said all along that it will be something simple that I am overlooking. I will find out if that does it.
Thanks.
Tim
SlowRoad
Hartselle AL
« Reply #9 on: September 03, 2009, 03:20:59 AM »
 uglystupid2  Well, I knew it would be something simple. It was the wiring from the coils to the plugs. I "ASSUMED" the guy had them wired correctly when the bike came in, but should have known better. Oh well, it's running good now so I can start on the other issues.
 cooldude  Thanks for all the suggestions. Guess I just needed something to jog my brain and make me start thinking. Cheesy
Tim
