February 10, 2026, 02:47:45 PM *
Author Topic: TEMP GAUGES  (Read 990 times)
Eric58701
Minot NorthDakota
« on: June 14, 2015, 07:59:55 AM »
OK time for more add on stuff, I am looking at the tel-tru oil temg gauge, anyone have any issues using one? .
And I would like to monitor the water temp as well , I would like to find a radiator cap if there is one available??
 And a 12 volt, accessory plug and or phone charger outlets,
 What ya all using ?
« Reply #1 on: June 14, 2015, 09:28:56 AM »
The TelTru is a good unit, but if you loosen it by twisting the face/sweep dial, you will alter the temp reading. (can be reset in boiling water 212*).  The housing that snugs over the dipstick hole threads is square, so use a wrench/small adjustable, not the gauge face.  I don't know if the oil line on the TelTru is accurate, I use an OE dip to check oil level (I don't know why, you drain/add a gallon and never need to check at all).
If you have an oil gauge, you really don't need a water gauge, though the water temp goes up before the oil.  In many years of riding, I have only gone a bit over 220* on my TelTru's a couple times (high temps and heavy traffic).  More of the cheapo radiator cap/temp gauges leak (on valks) than don't leak.
Lots of ways to go on accessory plugs.  First, figure out WHERE you want power, then choose a setup that gets you there.  I suck on auto electric.  Key switched and fused is a good idea.  Some of my stuff is always hot, and has drained the battery at lunch when I was looking at hooters instead of paying attention and turning stuff off.
brian1726
Epping melbourne australia
« Reply #2 on: July 04, 2015, 02:26:12 PM »
I have just fitted a temp & amp gauge as well as a charger plug
for my phone in my right saddle bag & a cigarette lighter/USB port in the
left saddle bag.
That is so that my wife & I can keep our phones charged while on the bike.
I plumbed the temp gauge sender into the top rad hose & everything works
fine.
It is all pretty easy to do...just take you're time & put a 15amp fuse
in all you're add on's.
It is winter time here in Aus so not much else to do while it is raining
& cold.
I have also wired in a gps,trailer plug & I'm playing with a set of LED running
lights to go on the crash bars.
cheers...
Brian  Smiley
longrider
Vernon, B.C. Canada
« Reply #3 on: July 04, 2015, 06:37:41 PM »
This has worked well for me for over 12 years
I'll get the photo here in a minute
« Last Edit: July 04, 2015, 06:43:14 PM by longrider » Logged
