May 13, 2026, 11:14:54 AM *
Author Topic: I've been doing some research on bluetooth CB radios  (Read 2858 times)
Dennis from Blythe
Blythe, Ca
« on: June 16, 2015, 11:56:35 AM »
During the conversations Dave, Wayne and I were having on our way back from Spearfish, that me getting a CB radio would be a great idea. They both have one and it made the long trip more enjoyable.
Wayne had mentioned of a Bluetooth CB system.
So, I did some research, and I discovered that a Bluetooth CB system does exist.  cooldude  Its been available for a few years now.
  Using this gadget as the Bluetooth hub,
  http://www.revzilla.com/motorcycle/sena-sr10-bluetooth-two-way-radio-adapter
   and getting this Midland hand held CB,
http://www.amazon.com/Midland-75-822-Channel-CB-Way-Radio/dp/B00000K2YR
  with using this adapter cord,
http://www.amazon.com/Sena-SC-A0117-Straight-Twin-Pin-Connector/dp/B0087NB4H0
  I should be able to use the Cardo scala Bluetooth communication system I all ready have,
http://www.revzilla.com/motorcycle/cardo-scala-rider-qz-headset
This idea sound very interesting. What do you guys think ?
  Cool
BigMac (SoCal)
Moreno Valley, California
« Reply #1 on: June 16, 2015, 12:09:26 PM »
It sounds great Dennis, my only concern would be the volume and making sure you could hear it well.
Dennis from Blythe
Blythe, Ca
« Reply #2 on: June 16, 2015, 12:52:58 PM »
Humm, yes the volume is quite low at the higher speeds, but is fine at the lower speeds with the navigation voice with the Bluetooth. It would probable be the same volume level at both speeds with the Bluetooth CB... right..  hum..
The wired connection you and Wayne have, the volume level is good at the higher speeds ?
definitely something I need to consider..
BigMac (SoCal)
« Reply #3 on: June 16, 2015, 07:21:37 PM »
Yes we can adjust the volume to just about anything we need.
