September 05, 2025, 02:00:21 AM
Turn signals wacky help!
Topic: Turn signals wacky help! (Read 604 times)
Tfrank59
'98 Tourer
Western Washington
June 16, 2015, 06:56:22 PM »
When I put on my turn signals now the front ones work fine but the rears don't come on at all, instead the tail light blinks! So I decided to do the turn signal switch cleaning maintenance, but that didn't help. Anybody know what causes this situation? Thanks.
-Tom
Keep the rubber side down. USMC '78-'84
Re: Turn signals wacky help!
June 16, 2015, 07:53:14 PM »
Look for, check all ground connections.
DenverDave
Out past Mars ain't no speed limit -Mojo
June 16, 2015, 08:30:27 PM »
The first place I would look is the electrical connector under the rear fender. There is a small metal "box", where the rear half of the fender meets the front half, that protects this connector. It is possible for the rear tire rub on the box and possibly damage the connector/wiring.
Dave
1999 interstate green/silver
Denver, Colorado
VRCC#32819
VRCCDS#0238
Tfrank59
'98 Tourer
Western Washington
June 16, 2015, 08:33:01 PM »
Hey thanks for the tip. So I just popped open my little fuse box pushed down on the fuses and bingo that was it! That was after I started messing around with all the wiring back up under the rear fender to make sure it was grounded.
-Tom
=> InZane XXV
