November 20, 2025, 01:44:23 AM *
Author Topic: Wher to get those short rubber CB/Radio antenas?  (Read 2079 times)
HotRod
Henderson, NV
« on: August 31, 2009, 01:41:42 PM »
Need em for super valking.
Andy
« Reply #1 on: August 31, 2009, 03:26:11 PM »
These guys might be able to help you: http://www.walcottcb.com/index.php
or these guys: http://www.sierra-mc.com/products.asp?cat=259
here's another: http://www.claysradioshop.com/jm_products_antenna_system.html
HotRod
Henderson, NV
« Reply #2 on: August 31, 2009, 03:53:46 PM »
Thanks Andy, cooldude
Grandpot
Fort Mill, South Carolina
« Reply #3 on: August 31, 2009, 08:10:04 PM »
I got mine at Autozone.  The antenna is OK, but none of the adapters fit the Valk antenna mount.  I was able to drill out one of the adapters and tap it to fit the Valk.  Works great.
chip
« Reply #4 on: September 01, 2009, 08:21:29 PM »
Hot rod ,please lt me know what you find in the way of an antenna. I've been following similar post. I maybe able to drill and tap one, or rig one . But I can't believe sombody dosent make what we are looking for in a direct replacment. Every website I go to has plenty of one and two foot replacements for the HD's.
Cliff
Manchester, NH
« Reply #5 on: September 02, 2009, 03:28:26 AM »
Ditto...
VRCC # 29680
HotRod
Henderson, NV
« Reply #6 on: September 02, 2009, 04:30:42 PM »
I'll be sure and let you know and you do the same man,thanks.
LadyDraco
TISE
« Reply #7 on: September 02, 2009, 07:07:27 PM »
Highbinder kept his OEM CB antenna.. And mounted it at the bottom of the saddle bag ..
You'll  need a splitter if you will drop it down to 1 antenna....
It looks good !!!
I have a shorty on my Black Valk and it sucks big time on the CB....
It looks good but has NO range... tickedoff
It's a sierra ...
Just my 2 cents....
« Last Edit: September 02, 2009, 07:15:17 PM by LadyDraco » Logged
This  is  the  way
Piper
San Antonio
« Reply #8 on: September 03, 2009, 04:28:38 AM »
 I went with a 4 foot Firestik NGP antenna.
I want my little radio to listen and be able to talk back.
No really good place to mount a antenna on a Standard and all the mounts I found were for Wings so I had to get creative.
Being a Ham (KE5CQI) I have no concept of Form over Function. I am hanging a stake mount rearward off my luggage rack. The NGP antenna came with a spring that I exchanged for a quick release. Do not want to get wapped in the noggin with the antenna.
Check ebay. I saw several antenna/cb mounts there for Wings that probably could be adapted for an IS without too much work. Ranged from $5 to $85.
~   /  And it's whispered that soon, if we all call the tune
  0/// Then the piper will lead us to reason
<|o>  And a new day will dawn for those who stand long
 /_\    And the forest will echo with laughter
« Reply #9 on: September 03, 2009, 06:34:15 AM »
Question:
How much do you use your CB?
How much range do you want?
If you reply, like normal before I Super Valk'ed the bike,
then mount a fire stick or the original antenna on the saddle bag rack.
Rubber duckies as we call them are usually only good for short distance as they use the body, (metal) of the vehicle mounted on for it's range, Plastic is not a good conductor for the little Duckie.
Call & talk to Sierra Electronics for a good suggestion on an antenna, sorry, I have forgotten his name.  Tell them you want to talk to the head honcho that goes to all the Bike events........
