February 10, 2026, 04:47:38 PM *
Author Topic: new wire set under$30  (Read 1646 times)
Dogster
My #1
North Jersey
« on: June 19, 2015, 01:15:12 PM »
Just want to say thanks to John Schmidt for the shoptalk write-up and email guidance with this upgrade...saved me over $150 and onlt took about an hour and a half. cooldude I'd like to add pic...can't seem to find how.
« Last Edit: June 19, 2015, 01:18:07 PM by Dogster » Logged
Dogster
My #1
North Jersey
« Reply #1 on: June 19, 2015, 01:31:42 PM »
Also, does anyone know what the ohms value of the ignition wire resistors should be? Can't seem to find a spec on that. Mine range from 4.67 - 4.99. Thanks.
BonS
Blue Springs, MO
« Reply #2 on: June 19, 2015, 03:33:41 PM »
They're a nominal 5K ohms. +/- 10% of that is fine. So anywhere from 4.5K to 5.5K ohms. And you're right, John's write up is great.
« Reply #3 on: June 20, 2015, 05:59:59 PM »
Don, email me the picture and I'll post it for you.
Dogster
My #1
North Jersey
« Reply #4 on: June 21, 2015, 05:17:43 AM »
Ok John. I will send it as an attachment. I hope that works. Thanks!
Dogster
My #1
North Jersey
« Reply #5 on: June 21, 2015, 05:25:19 AM »
Thanks BonS for the input on the resistors.
« Reply #6 on: June 21, 2015, 06:09:45 AM »
OK, here's what the wires look like before installation. Looking good so far but I still want to see it when it's all done.  cooldude
Dogster
My #1
North Jersey
« Reply #7 on: June 21, 2015, 06:33:00 AM »
Thanks for the guidance, and posting the pic John. I will send updated pictures soon. Bike is stripped down, parts going for paint, Woody's audio fairing, and Daryl's (f6customs) gauge relo kit due anytime now...Yay! and once I get my carbs all straightened out (see new post "carb issues"), re-assembly and riding!  Wink
Paladin528
« Reply #8 on: June 22, 2015, 04:55:11 AM »
do they come in Red?
Dogster
My #1
North Jersey
« Reply #9 on: June 22, 2015, 08:10:01 AM »
If you can find the 7mm copper core wire in red, then you can make 'em! I found that Accel also has the wire in blue. I used the yellow obviously. set available on Amazon.com under $29. John Scmidt's instructions are posted in Shoptalk. Easy upgrade. And since Bike Bandit wanted close to $200 for a set of OEM...it was a "no-brainer" for me. Cool
rhinor61
Northern California
« Reply #10 on: June 22, 2015, 11:57:13 AM »
Great info guys.
Can I just buy the bulk ACCEL cable?
Since Jegs sales this cable in bulk, 100 feet for $91.00 with free shipping
Accel 160090 - Accel SuperStock Plug Wires
http://www.jegs.com/i/Accel/110/160090/10002/-1?parentProductId=747765#moreDetails
I am assuming that total cable needed is less that 20 feet  total to replace the Valkyrie spark plug cables.
And since your reusing the old ends and boots I can build 5 complete sets for $18.20 ea.
I own 2 valkyries myself and a few friends I am just looking out for..
your thoughts?
John
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
Dogster
My #1
North Jersey
« Reply #11 on: June 22, 2015, 01:49:58 PM »
Well that would work, sure. My overall length of original wires came in at about 138 inches.. so about 13 1/2 feet. I am planning to route the cables out from behind intakes 5 & 6 like John Schmidt did on his bike. This will eat up some additional footage but not much. My carbs are still off so wont know exact until re-install sometime next week probably. John shows a close-up picture in the Shoptalk piece. Nice clean install. Just need a couple of loom kits. John gave me the source info for them... I found them on Amazon for $5.95 Spectre Performance #4245 if i recall.
Dogster
My #1
North Jersey
« Reply #12 on: June 23, 2015, 04:50:05 AM »
Check that... 138 inches more like 11.5 feet!
« Reply #13 on: June 23, 2015, 06:06:33 AM »
When I did mine some years ago, I bought Accel kit #3008.....7mm, stranded wire core, yellow. Same as your OEM wires except for color. It left me with enough extra to do the wiring on my GL1200 project bike and I still have some left over in case I ever need to replace a line on either bike.
« Last Edit: June 23, 2015, 06:14:16 AM by John Schmidt » Logged
rhinor61
Northern California
« Reply #14 on: June 23, 2015, 08:13:10 AM »
thanks for the wire separator info. I got 4 sets coming from Amazon.
Amazon also has the ACCEL 160090 100' Yellow Copper Spooled Wire for $75.72 with Free shipping for Prime members.
so if I can get approx. 8 sets from 100', that comes out to less than $10 per set...
WOW....
Thanks guys..
John
John
Northern California
VRCC #28001
Dogster
My #1
North Jersey
« Reply #15 on: June 23, 2015, 08:15:28 AM »
Hey John. That GL1200 looks like an interesting project!
« Reply #16 on: June 23, 2015, 09:39:10 AM »
It gives me something to do when I can't leave the wife alone(caretaker mode). Adapted a Valk tank, Valk handlebars, Valk controls, and Valk grips. I was going to use Valk wheels but the rear didn't fit with the rotot attached....too wide and I didn't want to spend the $$ to reconfigure the swingarm.
Dogster
My #1
North Jersey
« Reply #17 on: June 25, 2015, 07:38:00 AM »
John. FYI...While replacing the stainless steel dowels in the fuel rails  (redeye's kit) last night, it dawned on me that the old dowels may be perfect to re-use as spacers/standoffs to keep those aftermarket wire looms away from the carb linkage covers. I will try them out after I get everything re-assembled.
