February 10, 2026, 04:47:46 PM *
Author Topic: Ideas for I/S interior trunk light?  (Read 1048 times)
Dak44312
Akron, OH
« on: June 25, 2015, 07:27:23 AM »
Anybody wire up a LED interior trunk light? Would like something I can mount inside the lid that fires down into the trunk when opened ...on a merc switch, maybe even on a retractable cord, similar to what some OE's are doing with under hood lighting in cars but in a smaller package.
BobB
« Reply #1 on: June 25, 2015, 07:42:49 AM »
I have installed simple AAA battery operated LED puck lights in the lids of my saddle bags with hook and loop tape.  They can be removed to be used for other purposes.  Such lights are available at any big building store, Lowes,  Home Depot, etc.  A cheep and easy solution...
« Last Edit: June 25, 2015, 07:46:02 AM by BobB » Logged
PAVALKER
Pittsburgh, Pa
« Reply #2 on: June 25, 2015, 08:07:36 AM »
Harbor Freight has those blue LED lights that are usually free, which have a large LED area light and magnet on back plus a hook to use while on the road or the like.  It also has a small flashlight on the edge.  You  could mount a piece of metal under the trunk lid (especially if you have a trunk rack) and use the magnet to hold it.
That being said, I do have a pair of small lights each side that are switch operated....but only when the bike is on I believe....wired into tail light circuit.   I don't have the trunk mounted up right now, but it is on the shelf and I could take pics if ya want.  But, beings it is not wired up to battery for constant power, I still use that little blue HF light when the trunk is on.
Something to consider is a fault with that light where it might stay on while bike is off and parked and draw battery down.  Plus if you wire it up and want to consider Super Valk options, it would require another plug if wired to constant power.
A friend had a LED wired up in his trunk, with constant power in line with a power port for phone charging in the trunk.  The light was operated off a switch you might find similar to a refrigerator or freezer door, and turned on when the lid was opened.
« Last Edit: June 25, 2015, 08:11:03 AM by PAVALKER » Logged
John
BigBad1
1999 Interstate
Garner NC
« Reply #3 on: June 25, 2015, 01:24:52 PM »
I bought a set of cheap led lights from Auto Zone.  Each light block has four led's and there are four light blocks on the set. They have a slight downward angel so the lights do not glare in your eyes. I put one on each side and two in the rear of the trunk liner. I drilled small holes to run the wire between the liner and outer shell. I used a glove box light switch from a old BMW to activate the lights when the trunk is open and wired it to my aftermarket fuse box in a spot that is energized all of the time. It was really inexpensive but a pain to install because of taking the trunk apart. I had already replaced the original trunk plug with a 6 way trailer connector because I use the trunk brake lights as turn signals. I used the extra wire to power the trunk lights and still have only one connector to disconnect the trunk.
