February 10, 2026, 04:47:47 PM *
Author Topic: Your thoughts please on this tire  (Read 1355 times)
DarkSideR
Pueblo, Colorado
« on: June 30, 2015, 04:15:27 PM »
Sadly my Vredestein Sportrac 3 is at the end of it's life as a really great handling D/S tire. I am shopping for a new tire and think I found a gem, but... we will get back to the 'but' later.
First off what did I find? It is the Michelin Primacy HP (available in 205/60R16). Initial research find that it has a "European handling profile, featuring a rounder shoulder".
Specs are a V Speed Rating, 91 Load Index, and UTQG Rating of 240-A-A.
So far so good right? Well I read a review and I found these tires come on the new Toyota GT86, which is known as a car that is easy to drift. Supposedly these are rock hard eco tires but doesn't a 240-A-A rate them as sticky? They also come standard tires on Mercedes.
Help me out here. I don't want to be drifting the Valkyrie.
« Last Edit: June 30, 2015, 04:17:22 PM by Joshcornkid » Logged
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
Redline +
Northwest Washington
« Reply #1 on: June 30, 2015, 04:30:56 PM »
My thoughts? Probably a fine tire for a Mercedes or Toyota. Hope that helps Josh.
Redline Cool
« Reply #2 on: June 30, 2015, 05:57:23 PM »
Interesting reading.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=48
I didn't think a low UTQG meant sticky, so much as soft. (maybe the same thing, maybe not)
And with enough HP you can drift any tire.
I bet it would work fine, but not last too long.  Just guessing though.
Unfortunately for all of the money spent to test, brand and label the tires sold in the United States, the Uniform Tire Quality Grade Standards have not fully met their original goal of clearly informing consumers about the capabilities of their tires. Maybe it's because tires are so complex and their uses can be so varied, that the grades don't always reflect their actual performance in real world use.
« Last Edit: June 30, 2015, 06:08:15 PM by Jess from VA » Logged
TJ
Lake Placid , Fl.
« Reply #3 on: June 30, 2015, 08:05:40 PM »
See if you can find a Michelin Primacy Alpine PA3 ZP... You won't regret in....   cooldude
DarkSideR
Pueblo, Colorado
« Reply #4 on: July 01, 2015, 06:04:48 AM »
Redline Cool
I knew I should have passed you in one of those corners, with my big ol car tire thumbing it's nose at you as it went by.  Wink
VRCC#34410
VRCCDS#0263
DarkSideR
Pueblo, Colorado
« Reply #5 on: July 01, 2015, 06:09:58 AM »
I know another rider using a Vredestein Winter Tire. I'm on the fence on getting a winter tire. Any benefits that you know of over a sticky summer tire?
VRCC#34410
VRCCDS#0263
TJ
Lake Placid , Fl.
« Reply #6 on: July 01, 2015, 08:36:37 AM »
If I remember right ,the winter tire is sticker...
Tailgate Tommy
Fort Collins, Colorado
« Reply #7 on: July 01, 2015, 09:33:59 AM »
Josh, the Austone doesn't interest you??
mustang071965
those that dare, Succeed.
monticello Ar
« Reply #8 on: July 01, 2015, 11:05:26 AM »
going to replace my general altimax this winter due to age 5 years. i am looking at the yokohama avid envigor its rated the same as my old tire. and i like the rounded shoulders and tread design.
DarkSideR
Pueblo, Colorado
« Reply #9 on: July 01, 2015, 11:17:55 AM »
It does but man is it a very boring tire to look at. When I hot rod my bike I need something eye catching sticking out back there.
VRCC#34410
VRCCDS#0263
Tailgate Tommy
« Reply #10 on: July 01, 2015, 02:22:36 PM »
No matter how hard I try I can't get my head far enough back there to see it  Grin
O-B-1
Vancouver, WA
« Reply #11 on: July 01, 2015, 02:55:18 PM »
[Unfortunately for all of the money spent to test, brand and label the tires sold in the United States, the Uniform Tire Quality Grade Standards have not fully met their original goal of clearly informing consumers about the capabilities of their tires. Maybe it's because tires are so complex and their uses can be so varied, that the grades don't always reflect their actual performance in real world use.
[/i]
I had heard somewhere that the grade only applies as a comparison WITHIN the manufacturer, that each manufacturer varies greatly from the other as to the value of each rating.
David W. Mitchell
1999 Honda Valkyrie GL1500C
