February 10, 2026, 02:47:12 PM
fork seal leak (again), oil on header pipes
Topic: fork seal leak (again), oil on header pipes (Read 722 times)
garyheskett All 49 x 3 st.louis
St. Louis, Missouri
July 02, 2015, 10:46:09 AM »
A couple of weeks ago on a trip to Maine, my right fork seal started leaking again. Did the film trick again (the third time over the years) and the leak stopped. However, the fork oil blew back and covered the right front of the bike. Got all that cleaned up, but the fork oil on the header pipes has fried on. I've used a razor blade on marks on the exhaust farther back, boot marks etc., with success, but I've not been able to get the burned oil off the header pipes. Any suggestions? Thanks in advance. Gary
97 Standard, 150,000 miles, and yes, I plan to replace the seals, bushings, etc, in the near future (thanks again Joe), waiting for the special tool for spring change (thanks Chip).
Re: fork seal leak (again), oil on header pipes
July 02, 2015, 10:54:26 AM »
Oven cleaner?
Joe Hummer
Arnold, MO
July 02, 2015, 10:59:35 AM »
Just make sure you cover painted surfaces with tin foil. The oven cleaner will eat the paint off.
Spray it on...heat the bike up...wipe it off...just like cleaning your oven.
Just ask the wife how to do it.
Joe
1999 Valkyrie Interstate
July 02, 2015, 11:38:41 AM »
Smart n Final sells a product called Carbon Off. Works on boot soles burned on pipes. Oil should be good too.
