December 21, 2025, 12:20:05 AM *
Author Topic: Oil Change  (Read 1551 times)
Tundra
2014 Valkyrie 1800
Seminole, Florida
« on: July 04, 2015, 04:37:30 PM »
  All right, which one of you tightened my oil filter? Grin
Changed my oil today finding Mobil-1, 15x50 synthetic available in both quarts and 5 quart jugs in stock at Wally World. The jug rang up $5.00 less than priced, ($23.00)
  My filter was very tight, couldn't get it off with my filter wrench. I destroyed it with large channel locks but got it off. I only tighten by hand and always lube my o ring. Undecided
  I usually change at 3k intervals, however this went 5k. Maybe the extra miles seized it up?
« Last Edit: July 04, 2015, 05:26:19 PM by Tundra » Logged
FloridaValkRyder
Apopka, Florida
« Reply #1 on: July 04, 2015, 04:40:40 PM »
I have never had a problem getting my filter off Doug. I use a cheap filter wrench but it always spins off with minimal effort.
I still miss her.
sixlow
St. Augustine, Fl.
« Reply #2 on: July 04, 2015, 06:54:29 PM »
That sure does sound like foul play Doug,  Angry  I went 7k with Mobil 1 and Honda filter came off as it should. I hate Haters.
Grumpy
Tampa, Fl
« Reply #3 on: July 04, 2015, 07:09:43 PM »
I have had the same problem a few times, hand tighten, then fight the darn thing to get it off a few months later. Almost seems like the rubber gasket bonds to the motor.
Thunderbolt
Worthington Springs FL.
« Reply #4 on: July 05, 2015, 03:53:29 AM »
Must have been oil change day Doug.  My filter came off fine.  5000 or so miles is where I try to change.  Carb sync while I had the bike on the outside chock and upright.  Even though I took pictures of the Baker Air Wings before I took them apart to shine them up I found out that you can put them together any number of ways all but one of which is incorrect. Smiley
flsix
« Reply #5 on: July 05, 2015, 04:30:27 AM »
Doug I've found you can avoid all those pesky little problems like oil filters being too tight by never changing your oil filter. Evil Shocked 2funny
2013 F6B
           ESCHEW OBFUSCATION
Jack B
Two Rivers Wis
« Reply #6 on: July 05, 2015, 05:14:43 AM »
Maybe too many right turns?  Grin
Let’s RIDE
TJ
Lake Placid , Fl.
« Reply #7 on: July 05, 2015, 09:46:21 AM »
The gasket swells once it get hot...  ( people have the habit of tightening it till they can't turn it any more and that's wrong... It's a 1/4 turn once the gasket first makes contact...)
« Reply #8 on: July 05, 2015, 10:52:55 AM »
Doug, if you're using synthetic oil and changing it at 3k intervals, you're wasting some money. The need for that went out at least 20 yrs. ago, probably even farther back. The last "old" car I had was an '85 Fifth Ave. with nearly 200k on it when I traded. Had nothing but synthetic the entire time, still didn't use a drop of oil between changes at 6k miles. Our current car I use Mobil 1 in the car and Amsoil in the bike. The car goes a minimum of 6k miles between changes, often a bit more. The bike will also get changed every 5k, mostly because I don't get a chance to ride it as often as I'd like so I want to get rid of the acidity and start afresh. If I were able to ride/travel as in the past, I'd have no problem going 8k if it's mostly highway miles.
A year ago Rita gave her little Lexus to her granddaughter, nothing but synthetic in it for the well over 100k it had when given away. It ran perfect and didn't use a drop between 6k changes.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #9 on: July 05, 2015, 12:10:56 PM »
 Your right John, the Mobil 1 jug states 15k intervals, guaranteed protection.
I'm just a freak that way. Same with my truck and her suv... 3k. I like to pull the dipstick and see clean oil, like honey. I don't consider oil wasting money, lifeblood of the machine.
« Last Edit: July 12, 2015, 04:16:00 AM by Tundra » Logged
